Question about Garden
Rough Running I have a Craftsman tiller that will only run with the full choke on. When I move the choke to run it stalls. I do not get full power with the choke on
  • Anonymous Jan 04, 2009
    It's an old Pony 5 horse. Difficult to start, but fired right up with Quick Start after storage. Now, one minute it idles/runs fine with a lot of choke, next time it simply refuses to even cough or sputter. Spark looks good when plug removed. Compression seems low when cranking, but I have no feel for what good compression should be.
  • Anonymous Apr 27, 2009
    how do you find out how to adjust the mixture screw on the careurator?
    Problem Solver:
  • 8 Answers
It depends on the type of engine but it sounds like your carbeurator is running lean. there is and mixture adjustment screw on most of the older models, alot of the newer carbs. are pre set to emission standards. try a fuel additive called sea foam, this product has solved solved many of my fuel related issues.
Posted on Nov 16, 2008
Honda cg160 tiller the engine was running rough With choke all the way in, fine at halfway. then stopped moving forward,moves but no strength to till. What's wrong??
while your choke is out your engine is getting too much petrol . if it wont run well with choke in then its not getting enough. there is a small screw on the side of the carb ( air mixture ) they are usualy ( from screwed right in ) 1 and a half turns out, try with 1 and a half turns out start engine and adust either way so it idles nice ( try and warm engine up first ) also if you can't get it to idle you might have to strip card off and clean it ...hope this helps
Apr 23, 2015 | Honda Garden
Earthquake Vector Compact Tiller Model#26750
Did you pull the spark plug and clean it, as well as the plug well and compression ring. Blow it out with canned air and dry before replacing the plug. Be certain the plug GAP is correct and it is free of carbon deposits. Rest the plug, tighten by hand and let her go. See if that fixes the problem.
Feb 27, 2014 | Earthquake Vector Compact Front Tine...
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
Will only run on full choke
you have a plugged jet inside the carb take it apart and clean them all
Jun 12, 2012 | Craftsman 8.50 Torque Rating Rear Tine...
14" CRT 3.5 hp tiller,
Make sure your Air cleaner is not obstructed. Clean it!
Check your spark plug for the proper gap. Adjust your
LOW speed throttle screw. It may not be getting enough fuel flow. Check your fuel filter screen (Inside your gas tank). Good Luck
Sep 19, 2017 | Craftsman Garden
Craftsman tiller, 850 series, model 917.297032, Briggs and Stratton engine, will start but not run. If it does start, it's a rough idle, and it kills as soon as I move it off of choke. I have cleaned...
It could be the gas you are running in it, if it contains ethenol use some stabil in this type of gas. Ethenol attracts moisture and will cause the carbs. on small engines to gum up and get a fouled. I run 100% gas in everything. It may cost a little extra now but it will save you alot more in the long run!
Feb 26, 2011 | Craftsman Gas Mini - Tiller/Edger
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
Need spark plug gap. and carb setting
gap should be about .020 - Carb setting is adjusted while running - lo idle and hi - lo idle adjusted to the lowest RPM before it stalls or starts running rough, the hi is adjusted at full throttle for the smoothest / highest rpm
Jun 06, 2009 | Mantis 2-Cycle Tiller
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
482 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
