Channels blocked all channels seem to be blocked, i can't get anything else on the screen except the word 'blocked'
My sony trinitron tv is blocked how could i unblock it
Posted on Nov 22, 2009
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Black screen
Not good. Make sure you have not blocked cooling to TV. It need s air flow. sounds like overheating
Mar 25, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
I don't see anything on television when i'm playing ps2
What type of TV are you hooking the cables too? Most likely the TV settings will need to changed to one of the following.  TV1 or TV2 using the input button on the remote, or channel 3 or 4.  It depends the set up of the TV
Dec 02, 2008 | Sony PlayStation 2 (PS2) Console
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Word "video" on screen
I tried menu again, scrolled to channel set and automatically reset the channels.
Apr 05, 2008 | Sylvania Televison & Video
TV won't change channel
child lock is actvated
Jul 16, 2007 | RCA F27450 27" TV
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Electro Med Services...
