Question about HP LaserJet 4100n Printer
Hp laserjet 4001n
I have just gotta a 4100n printer. it comes with no instruction book.
its just the printer with a power cord. how do i connect it to the computer? like what kind of cable do i buy? its got three ports in the back, one bigger one, a smaller one, and a phone jack type one.
all i know is to go to the hp website and download the drivers. but im not sure as to which cable to buy to connect it to the computer.
its just for home use. thanks
  • agnes_sowins Nov 19, 2008
    thanks it worked!
  • 32 Answers
The cable you need to connect to your pc is a regular parallel cable. It is called, IEEE 1284 Bi-directional Parallel Cable.
If you intend to use the a USB port this is what you need; USB to DB-25. The printer connection of the cable is the same the only diffrence here is the USB female adapter for the pc.
Posted on Nov 19, 2008
I have a HP Laserjet 4100N with an error code 51.2. What part do I need and is it something I can do myself after receiving the part?
Jun 28, 2016 | HP LaserJet 4100n Printer
My hp laser jet 4001n has a paper jam and does not burn the tonner
please check fuser roller assembly.there is an problem with heater.
Jan 26, 2014 | HP LaserJet 4100N Parallel/Ethernet...
What cable do I need to connect to my Power Mac G4?
Your best bet would be a parallel to USB adapter if you can find one that is designed to work with MAC. The Belkin unit seems to get OK ratings. Or connect the 4100 to your network, as the title shows 4100N. Not sure about driver support under MAC, you will need to check for the drivers.
Jul 02, 2011 | HP LaserJet 4100n Printer
When powering up the hp laserjet 4100n printer, it makes loud noise, and also states paper jam error and says to open top cover but there is no jam
Thank you for contacting FixYa with your printer inquiry.
yror2cow4ujehy7na20urcensmog20sjgurjxm4tuhbyg-zg2zbskniapisbqy8nf1kewpzeogdnflqy9ha2khbu5k8s2c19uem0r7dwagust35jfphz810nyjeqc2hldzxft7w1k4xvjdgbtu1g=s90-cRB1-8974-000, 4000/4050/4100/4500/4550 Separation Roller" />
HP Laser Jet 4100 Loud noises and paper jams
This error happens when the Pickup Roller/Clutch wears out. It's quite common and easy to repair. Purchase and install Roller/Clutch Part Number RB1-8974-000CN
Action: Do a Google search on the following link [hp laserjet 4100 + Roller/Clutch problems ] and you will locate numerous vender's of this part number item.
It's easy to install. Just unplug the power cord and disconnect the network cable, then set the printer on its back
and remove tray number two. The roller clutch will be visible. It has a pinch release that allows you to slide it off
the shaft and re-install the new one. It should snap in place. Right the printer then reconnect network cable and power cord and power back up. Function should be restored.
Hope this helps helps. Please keep us updated and remember to rate this answer.
Mar 28, 2011 | HP LaserJet 4100n Printer
How can i fix the 81.0180 EIO 2 ERROR on the hp 4100n printer
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | HP LaserJet 4100n Printer
How do I connect my HP Laserjet 4100 to my router?
HP LaserJet 4100 printer C8049A HP LaserJet 4100n network-ready printer C8050A HP LaserJet 4100tn network-ready additional tray printer C8051A HP LaserJet 4100dtn network-ready duplex printer C8052A
Which model do you have? There is an optional card to install before you can have it connected to an Ethernet network if you just have the 4100 model.
Oct 29, 2010 | Computers & Internet
Printer does'nt initialize
This could be a Jetdirect network card fault. Remove the card and power the printer on. If it powers up and goes ready then power it off again, refit the card and try again.Sometime reseating the jetdirect card will sort this problem If it doesn't work, then i recommend replacing the jetdirect netwok card.
Oct 13, 2009 | HP LaserJet 4100dtn Printer
HP LASERJET 4100N Accessory interface port
The port that looks like a S-Video port is called the Fast infrared (FIR) port.
The port tah looks lik a serial port is an accessory port for optional paper handling accessories.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP LaserJet 4100n Printer
Regular Maintance
200,000 pages is pretty good, most people get around 150 - 170,000. The parts can be ordered from HP here:
Maintenance kits come with clear instructions and are usually done by the user. At most you will need a crosspoint screwdriver to undo a couple of screws (depends on the model).
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 26, 2009 | HP LaserJet 4100n Printer
50.4 fuser error for hp laserjet 4100n
If unplugging the power cord for 30 minutes does not cure the problem, you have a bad fuser.
Look in the back of the printer for 2 blue levers.
Make sure the fuser is locked in.
Dec 25, 2008 | HP LaserJet 4100n Printer
HP LaserJet 4100n Printer Logo
611 people viewed this question
Ben Johnson
