Question about Splendide 2000S Vented Washer/Dryer
Water Leak - Splendide WD802M
Equipment is seven years old. Worked fine so far. Recently water started to leak from the bottom hose structure (drain pump and/or attached hoses). The drain filter has been completely clogged (hasn't been cleaned in years). After cleaning the filter, the leak continues. Is it possible that the drain pump itself is leaking?
  • rapsak Dec 07, 2008
    I have the same problem. I am in the process of trying to buy a replacement pump. The seal is leaking and has been for quite some time. The pump is corroded from the water and although it was still operating it is not too far from burning out. I have the Splendide WD802M model. It is in a 2002 Gulf Stream Motor Home.
    Does anyone know where to buy a replacement pump?????
5 Suggested Answers
  • 19 Answers
SOURCE: Where would I find a water pump for a Splendide
http://www.splendide.com/wd2000s.htm also try www.westmorlandsales.com
Posted on Oct 23, 2010
  • 19 Answers
SOURCE: I do not have a book with instructions on how to
  • 19 Answers
SOURCE: age of splendide 2000, wd802m
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
Either of these could tell you about your specific unit.
Posted on Oct 24, 2010
tiger56h
  • 176 Answers
SOURCE: where can i order a
in D&L STOR
Posted on Dec 11, 2010
Had the unit for seven years, it started to leak water around the water valve. Bosch aqua Star 125x ng
You have to fix this leak around the water valve before
it causes damage to your equipment.
1. Close the water supply valve going to your tankless
water heater.
2. Unplug or close the natural gas valve.
3. Now, you can work fixing the leak.
4. Once completed, you can proceed to open the
natural gas valve as well as the water supply valve.
5. Then, have it tested to get it done.
5.
Nov 27, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Water leaks into the vehicle on the front,
It could be a plain old fashioned leak around the windscreen - difficult to find but try sitting in the car while somebody plays a water hose over the windscreen.
It could also be a blocked drain in the ventilation system - fresh air is normally drawn in to a car via vents at the bottom of the windscreen. These vents normally lead to a "box" like structure where any water that enters the vents drops to the bottom and then drains away via a short hose that runs to somewhere underneath the car.
If the drain outlet or hose gets blocked (by leaves for example), it can cause the box to fill with water to the point where it can leak out in to the passenger area.
Hope this helps you find the problem.
Nov 16, 2009 | 1999 Ford Taurus
I have an 11.5 year old Frigidaire Gallery with an increasing leak present at the end of each load. A drip pan has been enough to catch it so far, but am concerned I'm seeing more and more water. Expected...
could have a leaking drain hose, pump. If your handy and dont want to spend several hundred dollars for a new washer and the washer is working fine veside the leak, I would just fix the leak.
Aug 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Fisher Pakel 4 years old Water leak
possible its form the pmp assy underneath, youll need to tip unit back( the bottoms open, look for leaks, should be quite noticable
Feb 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water runs out of the bottom of the unit
Check your plastic water orifice. It is in the hose fitting connected to the outlet tube of the water solenoid. It should be a blue one. Mine was completely eaten through, allowing full water flow, and thus overflowing the distribution tray. I replaced mine yesterday and no more water drips. May as well reflace the filter on the inlet tube of the solenoid at the same time. I used a piece of very stiff, but thin, wire formed into a small hook to remove both old parts. Replacements are readily available from multiple sources on line.
Feb 05, 2009 | Aprilaire 700 Humidifier
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Leak
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Jun 16, 2008 | Danby 22 in. DDW396 Free-standing...
Machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
Mar 03, 2008 | Samsung WF337AA Front Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Splendide 2000S Vented Washer/Dryer Logo
124 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
