SOURCE: Zanussi fridge works intermittently. Maay
Hi, It could be the t-stat...but.. also many other things... If you are hearing a clicking or buzzing then check out the last two tips.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
SOURCE: We have bottom freezer model
it may be because the hole under the defrost coil is blocked with ice. There is an easy way to eliminate this problem in many refrigerators. Follow these simple steps to stop this problem from happening.
Now when the freezer goes into it?s defrost cycle a small amount of heat will be transferred by the wire down the hole to make sure that it remains ice free. This will solve your drainage problems with your freezer defrosting and water running into the refrigerator compartment
