Question about NetGear Wireless-G USB Adapter (WG111NAWG111US)
Connection problems i have a belkin router on one pc and on my other pc i have a netgear usb 2.0 adapter when the usb is on the internet the belkin can not connect and visa versa for the usb what good the problem be my provider is aol thanks for any ideas you have
    President:
  • 2,961 Answers
Is wireless connection enabled in your routers wireless settings and not encrypted in any way until a connection is established. Make sure your router is set to enable DHCP, as this will give your wireless card an IP address automatically. Ensure your card is set to obtain an ip address automatically. If not look in your routers setup(normally by typing 192.168.2.1, in your internet browser) to see what IP address and DNS address it has given your connected pc (eg 192.168.2.3). Then go into your cards properties and use the IP address 192.168.2.4, but the same DNS address(probably 255.255.255.0); then re start the wireless pc and the router if neccasary. If you still get no connection, ensure wireless light is on; on your router, and you have no obstacles in the way of the signal. If you are using WEP encryption it is normally a Shared key setting rather than an open key setting. Please reate this solution.
Posted on Nov 20, 2006
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111v3 USB adapter not connecting desktop to Belkin router. this notebook is working OK. The adapter has been working OK for about 3 weeks.
Try to download the newest driver from belkin that matches the version and model. Uninstall the old driver and install the new one. This should fix the issue. you will need a pc that is connected / working to the internet to get this done.
Jan 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My netgear usb connects to my wireless belkin..but no internet ?
this message comes when your computer is not getting the IP address from the router.
There are possible reasons for that.
1. DHCP on the router may be disabled.
2. If your network is secured , then you might not be typing the correct network key.
In both the cases , you will need to check the settings of the router.
You will need to access the router set up.
Click Here for more info about router settings
Nov 24, 2009 | Computers & Internet
Wireless adapter on 2nd computer is not connecting to my router
you put in the usb port then install the driver then you find it the wireless icon will came in the task bar right hand side in bottom then you right click on it then you got the option view viable networks click on it then you got the your ssid name just connect it then surf it
May 13, 2009 | NetGear WGR614 Router
My Computer is going toooooooo slow !!!!!!!!!!!!
theres a million things that can interfer with wireless...tin...cell phones, cordless phones and the like..but 11mbps is still really fast and chances are, your internet connection isnt even half that so your speed on the net shouldnt be effected...1mbps is usualy enough to load any website in seconds.
if your PC is slow, not jsut on the internet but in general (starting up, running apps) then its an issue with the pc and not the wireless.
but as a heads up, not trying to be mean, but netgear and belkin are cheap equipment.
Apr 26, 2009 | NetGear WGR614 Wireless Router
I purchased a Belkin N1 Wireless USB adapter recommended to me by PC World but it is not working correctly. It WILL locate my network but will NOT allow internet access on it. I did ask specifically in the...
Hi there!
Theoretically, it should work with each other. I didn't find any documentation at Belkin's site that states the N1 USB adapter being not compatible with 3rd party devices like your Netgear router.
From what I know is N-Draft's wireless technology should be backwards compatible with both wireless-B and wireless-G devices.
1. Do you have other working wireless devices at your network during that time that you have the N1 USB adapter?
2. Were you able to connect to your wireless network? If Yes, what was your IP address at the wireless computer incase you had the chance to check it?
Maybe you can try to inquire with Belkin about what you've encountered with their device for clarification.
Hope this helps!
May 04, 2008 | Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Connection problems
If Internet sharing is set up correctly one pc will be the one that connects directly to internet, the other will connect through a gateway or other device connected to your network. Check they have'nt both got the same IP address. Is this related to last problem, did you get the wireless card working wirelessly online?
Nov 20, 2006 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
126 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
