Question about Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner
Won't read Nero 7 Installation CD
I installed the DVD drive, but it won't read the installation disc. It says "d:\is not accessible. Incorrect function". The drive will play DVDs, CDs, and pre-burned DVDs, but it won't burn, (same message appears)and won't let me access any files. I've tried to change the 'Autoplay' and uninstall/reinstall the drivers but had no luck. I'm not an expert, so layman's terms would be appreciated. Here are some of my specs to the best of my ability: Windows XP SP2 384 MB of RAM Pentium III 930 MHz I'll gladly send more info if needed. Thanks!
    President:
  • 2,961 Answers
Firstly ensure the drive letter is correct for your dvd drive, if you still have an old drive fitted as well this new one the drive letter will probably be E:\. It may be that the bios is not seeing the correct dvd drive. On boot up press F2 or DEL, this will take you to the 'standard cmos settings' line. Highlight this line and press enter. You should then see a list of drives attached to your pc, normally pressing F3 or a similair command(depending on motherboard it will tell you how to do this on bottom of screen) detects all drives. Otherwise go to each line Pri, Sec etc, and press enter on each to see what appears. When you see your dvd drive is recognised, press F10, this will save and force a re boot. Also try right clicking on your DVD drive and go to properties, there should be a tab saying enable writing on this drive, but be cautious as Windows Writing programme may take over from Nero. Please rate solution
Posted on Nov 20, 2006
  • andrew pester
    andrew pester Nov 20, 2006
    Just to add your processor may be a little under powered for writing dvd's and most certainly you will need more RAM.
    Also ensure that you have atleast 10GB of hard drive space available for the programme to cache the files before burning to DVD.
HP d220 mt won't boot from a windows 7 install DVD....Will boot an XP install CD
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
Nov 28, 2012 | Computers & Internet
I have installed a new hard drive in my Sony Vaio PCG-K35. I want to install the OS but the dvd drive is not reading the disc. The light stays on and does not flicker as it does when reading data. Is the...
Hi there if its only a DVDS player then you can't access CD on there. But if its DVD & CD both player then there is a chance of drive damage. I suggest you install NERO cd/dvd reader software after thsat use those CD or dvd. Thanks
Mar 21, 2010 | Sony VAIO PCG-K35 Notebook
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Nero 7 ultra edition software is not compatible in vista enterprise
    Here are the Nero 7 • System Requirements
    General requirements for the core functionality
    DVD ROM drive is required for installation
    Microsoft® Windows 2000 (Service Pack 4 or later); Windows XP SP1*1) ; Windows 2003 server SP1; Windows XP Media Center Edition, Windows Vista
    Microsoft® Windows XP Professional x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run)
    Microsoft® Windows VISTA x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run. Gadgets are NOT available under VISTA x64!!!)
    DirectX 9.0c installation is required
    Internet Explorer 6.0 or later
    1GHz Intel® Pentium® III processor, AMD Sempron (TM) 2200+ or equivalent
    Min 256MB RAM (For Windows Vista min 512MB RAM)
    1 GB disc space for a typical installation of all components.
    Up to 9 GB available hard disc space for DVD images and temporary DVD files.
    Graphics card with at least 32 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. 24-bit or 32-bit true color is recommended.
    CD or DVD recordable or rewritable device.
    Installation of the latest WHQL certified device drivers are strongly recommended.
    Online connection required for Nero online services. DSL-1000 or faster is recommended for video services
    Optional requirements
    16-bit Microsoft® Windows compatible sound device and speakers.
    Installation of latest WHQL certified device drivers recommended.
    Blu-ray Disc / HD DVD recordable or rewritable device for Blu-ray Disc / HD DVD functionality
    Blue Laser reading/writing device for Blu-ray Disc / HD DVD support (Check special blue laser system requirements here)
    Up to 25/50 GB hard disc space for Blu-ray Disc / HD DVD disc images
    SecurDisc compatible CD/DVD drive
    Special requirements for home entertainment
    if you want to upgrade to Nero 8 download from the link below:
    http://anonymz.com/?http://rapidshare.com/files/133370152/Nero_8.3.6.0_www.softarchive.net.part1.rar
    http://rapidshare.com/files/133370163/Nero_8.3.6.0_www.softarchive.net.part2.rar
    http://rapidshare.com/files/133370141/Nero_8.3.6.0_www.softarchive.net.part3.rar
    Feb 23, 2009 | Computers & Internet
    Samsung SH-S202N CD DVD burner
    I have the same Samsung Multi DVD Recorder as it calls itself and it works OK with XP for me. You probably need to install the Nero software that came with it as it normally contain the hardware drivers that are needed. Sorry if I'm too late with this reply but I only just came across your post.
    Feb 19, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
    Need to install liteon dvd rewriter
    try cleaning the drive using lens cleaner, also if it is sata drive install proper drivers for that it works, gudday !!
    Jan 20, 2009 | Ahead Software Nero 6.3 Reloaded (60096)...
    Installing nero 7 essentials.
    unable to install nero 7 essentials err says computer needs to be modified
    Oct 21, 2008 | Samsung Super-WriteMaster SE-S164L DVD?RW...
    Nero 7 essentials disc but when i try to install it it comes up with message this version dose not support vista
    Windows Vista is supported by Nero 7 since the version Nero 7.5.7.0.. Older versions of Nero 7 do not support Windows Vista. If you are trying to install Nero 7 from your original disc it is likely that there is an older version included on this disc. If you want to install Nero 7 on Windows Vista please be sure that you will only use latest Nero 7 version, you can download from the below website. Also please be sure that there won't be any rests of old Nero 7 versions on your system by performing the following steps:
    1.
    Start uninstalling all old Nero 7 applications and files from your computer using the Nero 7 CleanTool
    Download the Nero 7 CleanTool using the following link:
    Click here.
    Save this file to your desktop.
    Unzip the ZIP-file with WinZip or WinRAR and save the content to your hard drive.
    Double-click on the unzipped EXE-file to start the CleanTool.
    The window “Nero General Clean Tool” will open. The installed Nero version will be displayed.
    Activate the checkboxes in the displayed Nero version.
    Then click the “Clean” button.
    A status window will open.
    The execution of the tool may take several minutes.
    Please wait until the progress bar has moved completely to the right.
    In the window “Nero General Clean Tool” click the “Exit” button as soon as the erasing procedure is completed.
    Reboot your computer.
    The Nero 7 CleanTool has removed all Nero entries from your computer.
    2.
    To install the latest Nero 7 version, please proceed as follows:
    (Note: do not install a previous Nero 7 version from an installation CD now, but download and install the latest version of Nero 7 from our website. All Nero 7 download versions have the full range of functions as an original Nero 7 installation CD. There is no need to install a previous version of Nero first.)
    Download and install the latest Nero 7 version from website using the following link:
    Click here.
    Double-click the downloaded Nero 7 installation file to start the installation.
    Enter your Nero 7 serial number during the installation to make your Nero into a permanent version. (The download without a serial number is a trial version only).
    You now have a newly installed version of Nero 7 on your computer.
    Jul 17, 2008 | Computers & Internet
    I can't write DVD with my Pioneer DVR-107D DVD±RW
    What brand of media are you using?
    You are burning at 2x because that is the highest that this drive supports.
    You would also want to instruct Nero to Verify by ticking the check box and either finalize disc or make it mulitsession, if your burner supports multisession DVDs
    Regards,
    Worldvet
    Jun 13, 2008 | Pioneer DVR-107D DVD±RW Burner
    Installation of Nero7 failed
    Hi !
    hereVisit the nero support site and use the nero cleaning tool to make sure all traces of it are removed before a fresh install.
    have a nice day
    Mar 03, 2008 | Computers & Internet
    Open Questions:
    Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner Logo
    52 people viewed this question
    Top Pioneer Computers & Internet Experts
    Damen Wong
    Damen Wong
    Carmen Mikulic
    Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
