Question about D-Link DI 514 Wireless Router (DI-514)
I changed the address for my router and now nothing works
I have a VOIP and it was sending incoming calls to voicemail. They told me to go to 192.168.0.1 and to change the ISP address there. Well I did that and now I cannot connect to the internet through my router and my phone does not work at all.
  • 4 Answers
I don't know what "they" told you to change?
But if you changed the router's IP Address and you don't know what it is, then there is only one
solution to get you back to ground zero.
With the router power ON, press and Hold about 10 seconds the RESET button close to the power input jack. You did not state which model router you have, but after the router is rebooted you need to hook up using a direct cable connection with the your browser using the following:
Type on address bar 192.168.0.1 enter. the Dlink router webpage should appear and asking for
Username and password.... Username is "Admin" Password is "dlink" these are the defaults.
From there you take over assign a new password, choose your encryption and password etc.
Best of luck
"Don't Fuss Ask Gus"
Posted on Dec 05, 2008
I can not get port to let me get in coming calls
Most likely your system has a firewall somewhere .
Could be the router. You need to log into the router and check TCP ports 5060 and 5061 are allowed in the firewall settings . ring your isp and ask them to help you get Voip incoming ports to work on your router for incoming Voip and tell them the device you are trying to use
Jan 01, 2015 | magicJack Plus
Can't call out and messages are not left on voicemail
If your magicJack does not read "Enter Number Here To Call" please contact Tech Chat for additional trouble shooting help.
International VoIP Phone Service Customer Care Support magicJack
Mar 24, 2014 | magicjack.com Computers & Internet
I just setup Nettalk Duo and can send and receive calls. But the Answering machine will not work. I have it set for 4 rings and Nettalk voicemail is set for 5 rings. Any suggestions, please help.
Login to your Nettalk account and click on the voicemail tab on the left. Make sure to turn off your voicemail settings for your Nettalk device and save settings. Your answering machine should now pick up after 4 rings.
Mar 11, 2011 | Uniden DECT 6.0 Cordless Phone ID
Good morning, I am trying to set up my voip (magicjack) on a DIR-655 wireless and I can send call but cannot receive them. I am not on the LAN as i am wireless, can you help
You _are_ on the LAN -- via your "wireless" connection.
However, the "unsolicited" TCP/IP traffic caused by the "incoming" call is being blocked by the firewall software inside the D-Link router.
Follow the MajicJack instructions for "port-forwarding", so that all that unsolicited traffic gets "forwarding" to the IP-address that is assigned by the router to your computer.
Feb 03, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Change time zone Dect 6.0 Dual handset
Singerjaxfl, I used to have the same problem with my Vtech DECT 6.0 phone. I solved it by changing the system time on my VOIP Adapter.
In order to do that, you need to (1) know the IP address of your VOIP Adapter (the manual should have it, or ask its manufacturer), and (2) have the Admin authority (again, the manual or manufacturer) to change system time.
Mar 16, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Can't access voice tab on WRP400
If your wireless VoIP router was provided by your VoIP provider they will usually lock this option on the router since they have pre-configured the voice settings(sip server, phone number, password, codecs) before they deliver the device to your location. if you have a working internet connection already you can give your VoIP proiver a call so that they can remotely check the voice settings on their end to verify if it's working or not.
Nov 24, 2008 | Linksys Wireless-G WRP200 Router
D-Link DIR-625
What you need to do is long into your router's configuration. For the D-links, all you have to do is open internet explorer. Type in 192.168.0.1 on the address bar and press enter. Once you get into the log in page, type in your username and password (not the same one as your wireless password). If you don't know. Try admin for username and leave password blank. It should work if you have not change the default password. Once inside the configuration page. Go to Advance, click on QoS engine on the left. Input the IP address of the VoIP box in the "source ip" , type in a name for your rule and select 1 for priority and input your ports for your VoIP box. The best thing you want to do is put your VoIP box before your router. That way you get better quality.
Oct 02, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cannot access the internet through my DIR-625
Check your IP address to 192.168.10.1 on the network settings
after that turn modem and VoIP off.
Click on Setup / Manual Internet
Select Dynamic IP under "My internet connection is"
Click on "Clone Your PC's Mac address"
Click on Save settings, if it ask for reboot click on reboot
After the router reboots (NOT COMPUTER), it will take you back to the router.
Once your are in the router, turn the modem on first then the VoIP.
After the modem and VoIP has finish rebootin
Click on the status tab of the router and check uder the "WAN"
Settings and check the IP address. If you get an IP address then check the internet.
If you do not get an IP address Click on Release and then renew.
If you still do not get an IP address click on Advance tab
Click on Advance network on the left and turn UPNP off and save the settings.
After that it should be able to get an IP address and you should be able to get online.
Nov 05, 2007 | D-Link DIR-625 (790069292637) Wireless...
D-Link DI 514 Wireless Router (DI-514) Logo
42 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
