Question about HP Office Equipment & Supplies
Print is real light on the first page and then nothing on the second page, and will not print in color. I replaced the cartridge.
The Lemark Optrasc1275 printer is given me a error of 30 black toner but i have change the black toner.
Posted on Nov 14, 2008
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
H P Photo smart C4280 Will not print color/; Prt cartridge just replaced
After replacing the cartridges, printer performs align print are you check this page? any color print in that? If you found colors in align page, no problem with printer.> check print command in color or not.. > If no color print in align page, perform clean cartridges > check with another cartridge.> check trailing cable,carriage PCB & Formatter..
Dec 06, 2011 | HP Photosmart C4280 All-in-One InkJet...
I changed the color ink cartridge and it still won't print.
The replacement cartridge may have a dried out print head, or there could be an air bubble in the ink cartridge preventing ink flow. The only thing you can really do at home is to press the bottom of the cartridge, the print head into a folded paper towel lightly moistened with warm distilled water. Be careful as the goal is to have ink soak out of the cartridge and could get on your hands. If the print head is in good shape you should see a foot print of the print head, a rectangle roughly the same size as the silver area on the cartridge. If not try a few more times. If still nothing the cartridge will need to be replaced. Cartridge World stores have equipment to prevent/repair these kinds of issues, so maybe you can give you closest one a call. :)
Jun 14, 2010 | HP PSC 1510 All-In-One InkJet Printer
Color cartridge won't print
sounds like when your in the print page, go to layout to either print in black or in color. i'm sure you've done this already but thought i would mention
also try this, take out the color cartridge and put back in. turn off all systems and turn on again to see if it reconfigures.
lastly, HP has an awesome web site for trouble shooting, check this out.
hope this helps and good luck
Apr 29, 2010 | HP PSC 1610 All-In-One InkJet Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Color lines/dashes at top and middle of page when printing.
Amand321,
Your problem lies with the fact that you manually refilled your cartridges. This is not recommended by any technician I know and your solution is in the replacement of all your cartridges with genuine brother consumables. It is going to be expencive, but it is the only real solution.
Gremlin11
Sep 29, 2008 | Brother MFC-9420CN All-In-One Laser...
I have an MP460 printer. Suddenly it won't print. When I try to print a document from Word, the printer acts like it's printing--goes through the motions, spits out a page, but nothing is on that page,...
  1. Open the front cover of the printer and remove both cartridges.
  2. Moisten a clean, lint-free cloth with water and gently wipe the gold nozzle area.
    Warning!
    Wipe the nozzles of the color cartridge in one direction so the colors do not mix.
  3. To dissolve dried ink, hold the damp cloth against the nozzles for about three seconds. Gently blot and wipe dry.
  4. Moisten another section of clean, lint-free cloth and gently wipe the gold contact area.
    Warning!
    Do not wipe the nozzles and contacts with the same section of cloth.
  5. To dissolve dried ink, hold the damp cloth against the nozzles for about three seconds. Gently blot and wipe dry. Let the gold-colored areas dry before you reinsert the cartridge into the printer.
  6. Reinsert the cartridge and repeat the nozzles test.
May 17, 2008 | Canon Office Equipment & Supplies
Very light print -- EASY SHARE 5300
papabuyme: try updating drivers...Disconnect printer from computer and double-click on C:\program files\kodak\printer\printerdriver\uninst.vbs. restart PC and re-connect printer when PC has boot up...if your problem persists...
you both need a new printhead. contact support
Guest: get a new printhead
May 09, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Ben Johnson
