Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Fridge has an odor recently
I have a side by side fridgedaire it has a filter in it which i am not sure what to do with it, it keeps blowing the gfi plug in the house and now it has an odor coming from the fridge. it is empty it was unplugged all through hurricaine ike we plugged it back in once power was restored and it started having this problem
  • 833 Answers
It is likely that you have a problem with the capacitor.  Look for it on top of the compressor.  If it is discolored or smells...you'll know!...replace it.  While you're there, clean out the condenser fins.
Posted on Nov 15, 2008
REFRIGERATOR HAS STOPPED WORKING , NOTHING RUNS, NO LIGHTS NOTHING
If everything is dead the first thing you have to establish is that the unit is receiving electrical power. It is far fetched for every component to go bad at the same time!!!!!!
Jun 25, 2015 | LG LSC27910ST Side by Side Refrigerator,...
Water smells from my side by side
Hello Maria, this is JK. I understand that you recently purchased a pre-owned refrigerator. Changing out the filter and the tubing were a great start to clean water. If you have not already, I would encourage you to run 10-12 glasses of water to freshen the supply and rinse out the tank. If you find that this odor and taste still persist, you may want to have the water tank replaced. Hope this helps!
Mar 18, 2014 | Frigidaire PLHS67EGSB Stainless Steel Side...
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
Have a Kenmore model 106.5702602 side-by-side for 1 year and can't get rid of freezer odor...have tried everything and can't put anything in freezer that isn't affected by this smell. Help!
the air blows from freezer to fridge side and then returns from fridge to freezer,so it could be and usually is something on fridge side causing odors or funny tasting ice cubes,check under bottom draws on fridge side,what kind of odor is it?
Nov 28, 2009 | Kenmore Refrigerators
FRIDGE IS BLOWING THE CIRCUIT BREAKER
Most likely you have a bad or weak circuit breaker. Consult an electrician for breaker change out. Make sure that it isn't hooked up with a GFI plug. They will not work on a GFI.
Apr 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Jan 24, 2009 | Refrigerators
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Fridgedair side by side
what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
