Frigidaire Gallery Washer Leaking around drum
So just for the sake of trying I'm not out anything if I try to fix it and it doesn't work. Does just the seal have to be replaced or does the bearing too on this model?
  • brianstaylor Nov 18, 2008
    So we have just decided to buy a new washer. It wont be a frigidaire. What is a good reliable washer for a good price?
    Scholar:
  • 66 Answers
You should always replace both. For the cost, it isn`t worth it to replace one, then put it back together and then find out that you should have replaced both of them. If I can help you any farther, I will.
Posted on Nov 14, 2008
  • Charles Caldwell Nov 18, 2008
    What you should do is find a appliance store that handles many deferent brands and talk to them about reliability and warranty issues. They are all about the same in my opinion. Some have better warranties than others. Some have better features than others. You`ll have to talk to a appliance center about these things and make a judgement on cost verses features and warranty. As an example Crosley has a ten year warranty on most of there products The cost is on the lower end but they may not wash as well or have as many features as some of the upper scale Whirlpool that have lower yrs on there waranties. So it`s hard to give much advice about that. It all depends on what your looking for, price, warranty, durability. You`ll have to compare to make a good dicision. As far as repaire, I think I have worked on every brand almost equaly. Anyway, it`s hard to tell wich brand I`ve worked on more. I hope I have been of some help to you.
Frigidaire stackable washer making loud clunking noise when spinning
You will need to take the front cover off and check to see if there is anything lodged between the drum and housing.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Tub will not completely drain.
try a hard reset unplug it for 30mins and try again
Jul 07, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Jun 27, 2009 | Frigidaire FEX831CS Top Load Stacked...
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
May 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer is leaking around bottom of the drum.
Yes, this does sound like the seal is bad. Unless you have replaced the bearing and seal in one of these bafore. It can be very dificult, without expierence. If not replaced correctly, it can still leak or can cause other problems.
Nov 14, 2008 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
