Question about Frigidaire FEF366 Electric Kitchen Range
2 wire from house 3 wire at stove
There are 2 black wires and 1 copper uncoated wire coming from my power panel, but my new convection oven says 1 white, 1 black and 1 red! what do I do?
  • Rstegall311 Nov 15, 2008
    jsrock516,
    Thanks that did help alot! after reading your solution I was able to retrieve the parts I clipped and looked at the wires in the wire nut. The balck with red was attached to the red from the old stove, black to black and the white & green to the copper or neutral wire. I hardwired the stove that way with total success!
    Rstegall311
  • Anonymous Feb 24, 2009
    3 wires 2 coated 1 note how do i hook up new stove to this older wiring scheme
  • 5,911 Answers
Okay, the normal color coding for a 220-240VAC receptacle is as follows:
White (Neutral) - 0VAC
Black (HOT) - 110 VAC
Red (HOT) - 110 VAC
I suspect that the two black wires from your power panel are the two hot leads in your case. That is...each one should read 110-120VAC. Verify this my measuring each black lead to ground. The copper wire is probably a ground or neutral. It sounds like this is an older house (?).
The following link will give you some advice as well:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
In addtion, the electric service for major appliances like a Range or Dryer should have its OWN dedicated circuit to prevent overloading. I hope you find this information helpful. If you have questions, please let me know.
Posted on Nov 14, 2008
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
Simpson stove has 2 2PH, 1 N and 1 E poles, but power lines only 3 wires-1 red, 1 black and 1 green. How to connect the wires to stove.
I believe the proper sequence is red to ph1 black to ph 2 and green to N and ground. Newer ovens do require a 4 wire plug and this is th esetup for them
Apr 02, 2014 | Ovens
I am hooking up a double oven to my house the wires coming from my house is black black and copper both blacks are hot the wires coming from the double oven is black red white and copper How do I hoo
The blacks are hots which wilkl give you 220 volts the bare one is the neutral conductor so the hook up the stove black to one lead red to the other white to bare.
Nov 06, 2012 | Ovens
Wiring Hunter ceiling fan into old house. My house was built in the 60's an the wiring is confusing. I removed an old chandelier and I am putting a new ceiling fan in it's place. When I removed the...
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Mar 20, 2012 | Hunter Dryers
I have an electric stove that has 1 black, 1 red
Since 1996, the NEC has required that all stoves and dryers be wired with a 4 wire configuration; 2 hot wires (red/black - supplies 240 volts), the bare green ground wire and a white neutral wire. Before you do anything, review this article which speaks to the 3-wire/4-wire arrangement. Good luck!
http://www.hammerzone.com/archives/elect/appliances/range1/cord/4_wire.htm
Mar 09, 2010 | General Electric Stove/Oven/Range Chrome...
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
We had a drop in stove and we replaced it with a new slide in but when we took out the old stove it was hard wired in. Soi cut the wires, there were threea black, white and a soild copper so i installed a...
Oh my! The white and black are normally both HOT wires!!! Bare copper is ALWAYS a ground wire, and also can work as neutral. Neutral is the middle prong on the plug.
Turn off the breaker before even touching your appliance, there might be 110v on the metal parts!!!
Black and white should be on the sides, and bare copper - in the middle.
Before switching the wires make sure that black and white really are the hot wires: there should be 220-240v between them.
Oct 14, 2009 | GE Profile JB968 Electric Kitchen Range
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
How do i wire a newworld es50s in. I`ve been having problems i`ve conected all wires and only had 2 of the hobs working
if its 240volt and you have a 3 wire receptacle, (crows foot) and the new stove has 4 wires:i.e. a RED-BLACK-WHITE-GREEN on the oven unit, your red/black are your 2 hot wires white goes to neutral, and Green is safety ground put the WHITE and GREEN together, as long as the receptacle comes DIRECTLY from the Main Panel in the House, they use a 4 wire systen in some locations depending on local codes/any new installs require a 4 wire plug install now per the N.E.C.
Aug 23, 2009 | Ovens
Just purchased new electric stove. The old stove had been hard wired. Black, white and copper. The new stove is asking to connect red, white and black. what should i do ?
Normaly black, white, copper (ground) is a 2-wire 110 volt, black white, red, copper is a 3-wire 220volt circuit. You must have a 3-wire cicuit run from circuit breaker box to stove connector.
Apr 28, 2009 | Kitchen Ranges
Frigidaire FEF366 Electric Kitchen Range Logo
183 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
