Question about Cisco AS5300 (AS535-4E1-120-AC) Gateway
Cisco AS5300 gateway FoIP problem
I have a Cisco AS5300 gateway. i have problems sending international faxes on FoIP (Fax over IP), although i can send local faxes. i wish to know if AS5300 does not support FoIP by itself, and what can i do to activate and make it able to send international faxes.
thanks for any help possible
    Problem Solver:
  • 10 Answers
Once I had a problem with Ethernet auto negotiation, fax-es and AS5300. all links in fax IP path had to be set to fixed configuration (ex. 100 Mbps full-duplex).
Cisco equipment could not autonegotiate link speed by itself (VG248, C3550 and AS5350), so it tried every few seconds to re-negotiate ethernet link speed, and those extra packets broke fax transmision over IP. Voice worked OK, at the same time.
Hope it helps..
Posted on Mar 19, 2009
Need to key number twice to send a fax
Its something that can't be changed... its to prevent faxing private and protected medical info or legal info to wrong #...
Dec 30, 2013 | Canon FAXPHONE L170 Plain Paper Laser
I own a Canon Pixma MP530 all-in-one fax,copier, printer,scanner. I cannot send or receive faxes since I switched my Comcast voip phone line from my office to my home phone, along with my MP530. The fax...
First try one step. The line which you have connected with the Fax, unplug any other phone from that line.
Call that number and see whether it rings or you get a fax tone.
Sep 13, 2008 | Office Equipment & Supplies
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
HOW TO EMAIL SCANNED DOCUMENTS FROM HP J4580 DIRECTLY?
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
International Faxing??
you need an international phone service and dialing capability on your phone, the country code for Australia is 61 so you would dial:-
011-61- Y- xxxxxxxx where 011 is international code from USA, 61 is country code Y is area code and xxxxx is fax number.
Just dial the number as sending a local fax
Dec 15, 2009 | HP 1040 Plain Paper Inkjet Fax
I need a fax sending from australia to england but unsure what the international code is for faxing and what numbers too take out, the uk fax number is 01803 521785....please help?
A fax is nothing but a normal homestyle phone line. Either go online to find a list of country codes or call your local operator for assistance.
Sep 22, 2009 | Office Equipment & Supplies
MY HP LASERJET 3050 WON'T SEND FAXES
While its possible, I doubt your doing it wrong...
  • Select [FAX], place the paper as indicated on the tray, type the number, and hit send. That's about it.
However, Fax machines will not send when attached to a digital phone network, used over IP phones, or in conjunction with DSL service without the lines being conditioned. This is a small device which hides the higher frequency noise from the fax machine. Any sort of signal shared on the lines may interfere with sending, recieving, or both. If you use DSL for example, I'd almost guarentee this is part of your problem.
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Feb 22, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Cannot send faxex
Did you try to send a fax to a different number? Also are you sending to a local number? Most send problems are poor phone line conditions. If you have tried to send to several different numbers with no success, then you can assume that the LIU board needs to be replaced. It costs about $40.00 from Brother for the part.
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
Cisco AS5300 (AS535-4E1-120-AC) Gateway Logo
280 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
