Question about Intertherm P3RA-048K Air Conditioner
Moter will not cut off
Looking for the fan realy.what it looks like.
  • burzerko
    burzerko May 11, 2010
    What type of unit and how old
    Make
    Manufacturer
    Need more info to dteremine which relay you have.
    Problem Solver:
  • 14 Answers
Is the thermostat set on fan on? Be sure the thermostat fan switch is all the way in the auto position..If you have a circuit board with a g terminal that is a gas furnace. Turn power off remove and isolate the green wire then turn power on. Let me know if it still runs. If it does not the circuit board is the most reasonable problem
Posted on Jan 10, 2009
How do I fix my 3 yr old vacuum Panasonic mc-ul596 upright cleaner rattled smelt electrical fume then stopped.
smell the moter if it smells like burnt electrical it may be fried but check the wiring real good before u give up alot of the time the wires start to melt before the moter
Mar 30, 2015 | Panasonic KX-TA824PK Phone
Heater fan moter good put new switch in and fan doesn,t work
Could be the blower motor resister,it's located by blower motor,2 screw hold it on.Here's what it looks like.
Dec 03, 2012 | 1990 Toyota Pickup
Moter bogges down during acceleration
I would check the TPS sensor( Throttle Postion sensor), My truck was doing the same thing one day, Some go out over time and others just stop. it is about 40+ dollars depending on the type of vehicle that you have. but it is worth a check, you can test it with a volt meter, serach utube they have a video on how to test them.
May 23, 2012 | 1992 Chevrolet C2500
Fan moter does not work is there a relay?
Yes there is, but there is also a Fuse and Cooling fan switch.Those are tree thing that you are looking for.I don't think motor is blown,because you car is not that old at all.
Jan 05, 2010 | 2004 Toyota 4Runner
The dc cooling fan for the projection lamp has stoped running I am looking to buy a replacement fan moter.the existing fan is a nonoi brand model g9232l06b2 thanks
Go to Encompas Parts Distrubtion online they will Listed all the parts to your TV just type in your model # or Call 1-800-638-3328
Dec 29, 2009 | Televison & Video
My Acer aspire 7720 seems to be performing as usual, except that the screen has become scrambled after i have a power cut
its the graphic chip overheating, this needs a repair technician to take a look it better be a realy realy smart one not anyone can do this job.
Nov 25, 2009 | Acer Aspire 7720 Notebook
Looking for a picture or diagram of 2002 dodge durango 5.9 as i got my vehicle back from shop having the water pump replaced. they went ahead and replaced the thermastat and upper hose and assembly for...
If the fan is running backwards, you should be able to fell the "breeze" from the outside of the vehicle, near the radiator. Also, If you spray the outside of the radiator with some water, if the fan is running backwards, the water will be spraying out when the engine is running.
Aug 19, 2009 | 2002 Dodge Durango
My fan is truning slow. I need to find where the temp sensor or the fan realy is so i could check it out. Our what do you suggest.
if the fan is turning slow measure the voltage at the fan connector, if it is at or above battery voltage then the fan motor is shot, replace it. also verify the connector is not burnt looking which is a common problem.
Mar 02, 2009 | 1998 Cadillac DeVille
Fan for heater not working
did you put power to the fan to see if it is good? did you check the fuse ?did you look at the blower resister?
Dec 06, 2008 | 2005 Chevrolet Colorado
1997 plymouth neon, i can smell something burning after driving for a while. coolant fan not coming on. fuse seems to be ok.
it may be ur brakes or your fan moter is trying to turn and can so its melting the plastic on the moter i would get it looked at if i were u or just replace it all it not that expensive
Jul 30, 2008 | 1995 Plymouth Neon
Intertherm P3RA-048K Air Conditioner Logo
51 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
