Question about HP 610 Color Copier
Copy is not clear and the txt is double
While making copies the txt or picure seems out of focus and doubling occurs in it. I have checked/replaced the cargrdiges, sevice the machine but of not good.
  • 328 Answers
Sounds like the scanner is not moving freely. Try lubricating the scanner rails. And the obvious, clean the glass with windex.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 01, 2007
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
Problem with Konica 7145.. When i make copies it duplicates some lines and reprints them lower on page (more faded) and also the first lines of the copy are blured in a point that they are not readabl
Manousos Xatzidakis:
I would take another look at the drum cleaning blade as well as the CEL and PTL. Any time I've had problems with double images, the drum carriage and parts associated to it have been the problem. I remember one notable case where I removed and shrouded the drum to protect it from light, cleaned both the charge corona and the discharge corona, cleaned the PCL and the PTL of toner dust, vacuumed the drum carriage of toner dust, cleaned the developer unit and replaced the developer. I finally got clear copies and the customer was satisfied.
Sep 22, 2012 | Konica Minolta Office Equipment & Supplies
How delete double contacts no. in phone book,sim
double contact occur dur to copy of same contact from sim to handset or to handset to sim.go for contact select delete all and then sim1 r sim 2 after that enter security code(default:0000).
FORGET CODE:first make a copy of handset nos to sim1 while doing select the option DELETE ORIGINAL
Feb 03, 2011 | LG GX200 Cell Phone
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
My taskbar wont work and the message team H20 CLEDEX has stopped working appears, how do i fix it without resetting to factory settings
Greetings,
To fix the issue please download Deckard's System Scanner (DSS) and save it to your Desktop.
  • Close all other windows before proceeding.
  • Double-click on dss.exe and follow the prompts.
  • When it has finished, dss will open two Notepads main.txt and extra.txt -- please copy (CTRL+A and then CTRL+C) and paste (CTRL+V) the contents of main.txt and extra.txt in your next reply.
Regards,
TechSup1
Apr 29, 2009 | Microsoft Computers & Internet
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
How do i make double sided copies for my HP 2840
When the printer window pops up, click on preferences then features to enable manual two-sided printing.
Dec 21, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Double imaging on a sharp small copier
Check the drum cleaning blade.if it is ok check the fuser roller.
Sep 21, 2007 | Office Equipment & Supplies
HP 610 Color Copier Logo
Clive
Clive
