Question about Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive
Drivers I have a Beyond Micro External Data storage device, 120 GB. Trying to locate Vista drivers for this.
  • Anonymous Mar 02, 2009
    you are completely stupid. what a totally worthless comment.
    Problem Solver:
  • 7 Answers
The only DRiver is already supplied with OS 2000pro & up as Firewire. Problem connecting is due to the Supplied Power Supply. Wattage is too low at 1.5. Try a higher Power Supply.
Posted on Feb 01, 2009
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My 10 pin data connector broke off inside the case--can I take this somewhere for assistance with repair and data recovery off of my device? it is a maxtor one touch III mini
The answer is Yes.
You can recover lost data from USB with data recovery program.
CardData Recovery can recover data from all camera flash memory cards includingCompact Flash Card (CF), Smart Media Card, Secure Digital Card (SD),Multi-Media Card (MMC), XD Picture Card (XD), Micro Drive, Sony Memory Stick(Duo, Pro), as well as removable storage including Zip disk, USB drives andHard drives. Recovery of files is also possible even when drive has beenformatted.
Oct 25, 2010 | Maxtor OneTouch III Mini Edition 120GB...
No current driver for Smartdisk 120 GB HD, needed for Vista Ultimate 64bit
Any external drive uses a USB connection, and Windows Vista will recognize this "plug-and-play" device, using the built-in device-drivers.
What problems are you having?
Exactly what error-messages are you getting?
Sep 28, 2010 | SmartDisk (USBFP120P) 120 GB Hard Drive
I have a Beyond Micro 500 GB External HDD. When we plug it into the computer and doesn't respond to the computer. We hear the fan in the drive but it doesn't appear on computer? Can you help? Whats...
The sound you hear is the sound of the disc which is running anyway it may be a driver issue please uninstall the driver then restart the PC and reinstall the driver and check the issue.
Aug 27, 2010 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
External Hard Drive - Beyond Micro
I have the same BMMDU2. It's used 12V/1.5A power suply.
May 11, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
I have a Beyond Micro MobileDisk 300GB 5400/2MB Ext HDD. My Dell Inspiron 1721 laptop with Window Vista won't recognize this external hard drive. Is there a new driver to download or some other way to fix...
I am giving you magic out of my pendora box..........
As your system has got infection so booting it normally actually wont help you much so kindly boot your system in safemode with networking and download following
2.Trojan Remover.exe
Now update it and run them one by one in sequence ,This will free your system from any harmfull infection may it be ,you ve mentioned that you are not able to open the pen drive it is because of trojan so keep your removable media plugged and then after finishing operation in safe mode run the same in normal mode
Now these steps not omly fixes the problem but makes your pc 20-30 times fast depending upon configuration as ypur sytem performace will be automatically optimized and prevent and future intrusion
First things first .....check for power cable and data cable and make sure they are not tampered or damaged now move to next step>>>
kindly remove all jumpers in HDD now go to
Control panel>Administrative tool>Computer management>Disk management
you can see the disk here and change settings accordingly like assigning path and drive letter if this does not work
then just see that is it recognized in device manager as unrecognized device then update driver for HDD even now if the problem persists
KIndly consult the manufacturer
One more thing you asked about drivers let me inform you that OS Drivers natively supports this
Thanks And Regards
May 09, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive Logo
344 people viewed this question
Top Beyond Micro Computers & Internet Experts
Dean Rigsby
Dean Rigsby
Level 1 Expert
Joe Bit
Joe Bit
Level 1 Expert
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
