Question about Samsung Televison & Video
2006 - HLR6167WAX/XAA - 1966
I have a HLR6167WAX/XAA purchased in 2006 with 1966 Usage Hours. For no apparent reason (ie no power surge etc. screen began freezing, remote becomes unresponsive, must unplug to turn off, picture may suddenly come back fine, or come back as a broken up image(but not green or black and white),periodic falshes of green panels on otherwise good picture, TV Guide just shows up randomly when channel was changed. Initially fully powering down correct for 1-2 days, but now that solution works for 1-2 minutes. Diagnosed via multiple forums as likely a DMD problem. I replaced the L6 DMD Assembly, repowered and still have the same issues. Help!
  • endzb Nov 14, 2008
    I would not think that signal strength would affect ability to turn set on and off or use remote to shift between sources. Has same problem even if HDMI input from DVD is the source. Also sound stays on even when picture freezes or goes black in the TV mode.
    These had previously led me toward thinking it was the DMD being the problem.
    Scholar:
  • 181 Answers
Any thing like capacitor or ics getting loose on the main board can cause this freezing problem.if everything seems proper there there is definately the power supply failure problem.where something is getting short due to over heat.or the device is not getting required voltage to run perfectly.
first check out the board and locate any loose component.then go for power supply repais and voltage check.your problem will be solved.
Posted on Nov 14, 2008
  • 734 Answers
Your tv have sum lousing problem in SDMI cable and internal main board so, you should need a repair if you want to repair yourself then download service manual from given link (12 usd)
http://www.tvtechcenter.com/xcart/manufacturers.php?manufacturerid=5&sort=&sort_direction=&page=15
  • Samsung Master
  • 19,396 Answers
Did you test voltages at DMD board before replacing it?
The problem can also be caused by a bad ballast board, bad power board and problems on digital board.
See this solution here.
    Genius:
  • 1,550 Answers
I think your antenna signal was weak and you should get an amplifier .
There is also chance of software bug in the tuner. The tuner may be defective.
Motor failure after less than 5 years
hi there.well its an electrical item after all.assuming that all other reasons has been checked ie(1- power cuts 2- power surge 3- hot room temperatures 4-refrigerant leaks 5-internal bloackages etc...or plain and simple bad luck.ALI
Oct 07, 2013 | Amana 22.6 cu. ft. Side-By-Side...
HLR6167WAX/XAA samsung tv wont turn on i already replace the lamp and the ballast but i still get the flaashing light
Tv also have a colors wheel.Now u turn the tv on,u hear squiling,motor or whinning noises?Yes,the colors wheel is dead,replaced the colors wheel.The tv will,work agian.
Aug 05, 2010 | Samsung Televison & Video
Hi team I have 230volts at input pl32 but on switch on . Fault may have been a power surge .Thank you for any help Ray Styles ALSO badged Goodmans and Kenwood. pvr 160gB twin tuner hdd recorder
have you checked i f the rectifiers -diodes are stopping the minus part of the ac current,making it a dc voltage,ther either 4 single diodes or 1 round one which has 4 legs you want to measure the terminal marked with a plus sign i think,this should be a smooth dc voltage of half the input ac voltage ,in this case around 115 vdc.,it may been a power surge have you the mains suppressent capacitor,s this usually there to take the surge of 240 mains supply ,supplied by your energy company.during busy usage,there is usually a power surge ie,during tv ads,ets. is there any input /output current/voltage,to the dc transformer or out of it,have you followed the voltage/current throug the power supply circuit.
May 11, 2010 | Televison & Video
I have an RCA tv model #HD56W58 purchased in 2006. A month ago, we dropped the ground to the house, and the 220 surge took out most of our other TV sets, but this one seemed to be fine. Suddenly the...
May or may be not, but there are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 25, 2009 | RCA L42WD250 42 in. LCD HDTV
When i turn on my samsung 62'' inch rear projection tv(model#HLR6167WAX/XAA) it begins to whine like a fan working overtime, I will get a picture for about 5-8 seconds, and then it will cut off and the...
Hi.The ballast may be defective if you hear constant clicking sounds after you've pressed the power button.
If there are no clicking sounds after you press the power button(3-5 clicks every 2-3 seconds), this will confirm optimal ballast performance and, it will also confirm a major issue that concerns the Power distribution board. There are several weak or damaged components on the board that have failed.
The replacement of the power board is recommended in this case.
Jul 08, 2009 | Samsung Televison & Video
Runs slow then stops for no apparent reason
You can contact us at www.arrowpools.net for service. There is also a FAQ for Dolphins in the FAQ section.
You can also try the manufacturer at www.maytronicsus.com for answers. It may be the power supply but is more likely an issue in the motor pack. It may still be under warranty depending on the purchase date and model. Some have 3 year motor warranties.
Jun 30, 2009 | Smart Pool Inc Dolphin Diagnostic...
Blowin blue with V twin Quad with only 61 hours
I would put more oil in it and would ride the bike and see if the rings will unstick. Just keep a eye on the oil when running it!!! If this doesn't work then a good chance you will need to rebuild the top end.
Nov 22, 2008 | kawasaki Full Suspension Mountain Bike Men
Televison & Video Logo
269 people viewed this question
Henry  Thomas
Henry Thomas
