Hello, My name is Harlee and i just got a new printer and i just want to know is if my printer is wireless or not because in didn't come with a cord that connects from me laptop to the printer. Well i hope you will get back to me soon.
    Genius:
  • 1,124 Answers
The printer does not include a cord to connect to your computer. You have to buy it separately.
The cable is a USB universal printer cable.
Posted on Nov 14, 2008
  • Pablo Csaky
    Pablo Csaky Nov 14, 2008
    If your printer is wireless you will need to set the printer to the wireless network. Let me know the model and brand of your printer and i will help you more accurately.
B853A8C8 & B8539B14
You may try the below steps ...
  1. Make sure the printer is ON
  2. Unplug the power cord from back of the printer .
  3. If you have a wireless router, then power it off too.
  4. Wait for full 60 seconds.
  5. Plug in the power cord directly to a wall outlet ( bypass the surge / power strip )
  6. Also plug in the power cord to back of the printer.
  7. The printer should Power On automatically , if not you may have to press the ON button to do so.
  8. The printer should make noise and then prompt you to install the ink cartridges. Continue with the printer setup.
  9. Power ON the Wireless Router.
  10. If issue still persists, then contact HP for further support as it could be firmware issue
Jan 01, 2014 | HP Photosmart C7280 Printer
Hello, After putting my computer, hp pavilion m7690n, to sleep last night. I woke up to see it was turned off so I went to hit the power button to start it up but it didn't show any power because the...
It's possible that your computer froze during sleep. First, unplug the power cord, (with the cord removed) press the power button for 10-20 seconds. PS: You will lose any unsaved data prior to sleep mode. Let me know if this doesn't resolve your problem, might be something major.
Jul 01, 2013 | Computers & Internet
Were having problems connecting our Wii to our router we have a Cisco E2000 router. on the Wii a screen pops up when im trying to connect that asks for a SSID n i cant find that on the rounter or anywhere...
Your SSID is the name of your wireless network, which you probably entered yourself when you set up your router. If you didn't change anything, its probably something like generic like: "ciscoxxxx" or "linksys".
Jul 24, 2011 | Nintendo Wii Console
My hp f4280 printer don't have power to on.
hi misssim31, if the printer is not turning on..there might be a possibility that the power module is already faulty. if the power module light is lit up (the green light on it) try to plug the cord into different wall outlet and if it didn't worked..change the power cord and the module..and still if it didn't worked then the port on the back of the printer where you plugged the power cord is no longer working.
if you have any further question..dont hesitate to reply..
thanks
May 29, 2011 | HP DeskJet F4280 All In One Printer InkJet
I have a HP officejet 8500 wirelsss. It had worked finme since we nought it abiout 4 months ago. Now we can't print from any PC...says "disconnected. We did have a TWC technicina in to replace the...
If they installed a Modem/Access point that the computer talks to via wireless than this has become the new "hub"You may need to tell the printer the new settings so it knows to go through this "hub" 1. Press Setup 2. Scroll Down to network, press OK 3 Scroll to wireless network setup (could also be named Automatic Wireless Setup or Wireless Setup Wizard). Press OK 4. Highlight the Wireless Modems name, it will ask you for a password that the TWC man advised you, or you have set up. 5. It should connect to this and hopefully resolve your printing issue.
I hope this helps, if so please rate this response below Thank You for supporting the FixYa Community Regards GM
Apr 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have an HP Photosmart c4795 printer and it has a mind of its own. There is an error code (?) of 824C1300 on the printer screen. Help
Hello rcassity. The error code you are receiving likely is the result of a problem with the printer's power adapter. Be sure to double check that the power adapter connected to the printer is the proper one and that the Voltage of the printer matches that listed on the cord. You can also try resetting the printer's power by following a few quick steps: Start by unplugging the power cord from the printer and then from the wall so that no charge is going through it. If the power cord connects into a power module (resembles a block) separate the cord from the module. After waiting for 15-20 seconds reconnect the cord to the power module. Then plug the power cord directly into the wall outlet. Continue by connecting the power cord to the printer.
Lastly, press and release the printer's ON/POWER button to power the printer back on. Be sure not to hold the power button down.
I hope this helps! Be sure to reply if this has not completely resolved your issue.
Feb 28, 2011 | HP Office Equipment & Supplies
I dont know how to change the SSID Name and WEP Key.
You have to change it in the printer settings, not in the router! Otherwise you'll lose connectivity in all the other computers that use this router.
The SSID is the name you gave to your wireless network, and the WEP key is the password you set for your wireless connection.
Oct 28, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Need usb cord
Hello
You can for example use this "USB 2.0 AM-BM Printer Cable"
http://www.dealextreme.com/details.dx/sku.750
Apr 21, 2009 | Dell 924 All-in-One InkJet Printer
Scanner
Hi, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 13, 2008 | HP Photosmart C7280 Laser Printer
Wireless printer not working
Me too..., and I contacted Epson and they said they know the problem and work on it but they didn´t offer any help at all (!)
Jan 20, 2008 | Epson Stylus CX6600 All-In-One InkJet...
32 people viewed this question
jasbo
jasbo
