Question about Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer Time keeps going forever
I have neptune dryer MDE3000AYW, the dryer never stops the timer passes ver off position and never stops it keeps going. The only way to stop is to open the door.
  • Suresh Benegalrao
    Suresh Benegalrao Dec 06, 2008
    I HAVE MAYTAG NEPTUNE ELECTIRC DRYER MDE3000AYW THE TIMER KEEPS GOING ON ROUND AND ROUND IF THE DOOR IS NOT OPENED THE TUMBLER WILL KEEP GOING ON. I DON'T THINK IT IS THE START BUTTON STUCK IF IT WAS THEN AS SOON AS THE DOOR IS CLOSED IT SHOULD KEEP GOING ON, WHICH IT DOES NOT UNTILL THE START BUTTON IS PRESSED ON. ANYONE HAS SOLUTION?
  • 41 Answers
Your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Posted on Nov 18, 2008
Maytag neptune dryer model mde3000ayw wont start
If it only runs with start button held in then you have a problem with the door switch. Check to be sure the wires are on it. Here is the switch to order in case it is bad.
Nov 29, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Jul 08, 2008 | Maytag MDE2600 Electric Dryer
The neptune dryer timer doesnt work at all, it dryer fine just the timer button never moves and doesnt shut off.
Hi gordydugg...
Replace your timer it is defective and non repairable...
When you go to replace with your new timer, I would recommend that you remove and replace one wire at a time.
Please take time to rate me thumbs up
Sep 19, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune MDE3000AYW serial no. 12307603UU. The dryer will not turn on. I can hear the timer clicking but when you push the start button it will not start. The door is closed. I have...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE3000AYW. The start button on my dryer went out. It tried to start and then died and smelled burnt. I am guessing the switch burned up. Any thoughts on how to fix it? Thanks
sounds like motor is in a bind see if you can rotate drum by hand if you cant then your belt is hung up,or a belt pully is bad,if drum turns freely,sound like motor is going bad
Jan 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune Dryer (MDE4000) won't stop. The timer advances right past the "Off" position and keeps on going around and around until we open the door to stop it. The dryer gets very hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 10, 2010 | Maytag Neptune MDE4000 Electric Dryer
I have the MDE3000AYW gas dryer and the roller
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Maytag MDE9316 Dryer
Cold blooded neptune
check the hi-limit switch on the element case and the cycling switch also there for continuity,then check the thermal fuse for continuity its in the exhaust vent area
Mar 03, 2010 | Fisher and Paykel DEGX1 Electric Dryer
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
264 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
