Question about Aiwa Z-HT65 Shelf System
Aiwa CX-ZHT63 Display Trouble
I have this stereo system that the display is out. One night the breaker in my home that this was plugged into kicked off and when it was turned back on the display was out. Everything else works fine, the sound is great, CD works, and so on. The problem is that you cannot see what station is playing or the settings of the sound since the display will not light up. I really like this system and don't want to trash it just yet. Is there any suggestions that I can do, maybe a fuse is out, or the display can be changed. Please help!
  • 5 more comments
  • dlynn Jan 09, 2008
    I'm having trouble with the display on my aiwa cx-zht65 5disc stereo system. I use it in my entertainment center and don't want to have to replace it, but the display won't light. Everything else works and lights except for the display so I can't see the speaker levels and stereo stations, etc. I'll take apart myself, but I thought maybe I could find the answer first. Can anyone please help me?
  • Stryker395 Apr 06, 2008
    I have the exact same problem My system was working fine and the all of a sudden I go to turn it on and the display won't work. Everything else works fine, but I just can't see anything like volume or any of the settings. I really don't want to get rid of it just yet. If someone could please help.
  • schthed Apr 27, 2008
    I have the same problem on my aiwa nsx-mt960 are there any suggestions??
  • twracing937 May 17, 2008
    When I turn on the stereo unit I get the same thing that these other people are experiencing.  There is no display of the radio station, volume, or sound settings. I don't really want to trash this system if I don't have to.
  • crabbinboots May 24, 2008
    Add me to the list. Have been trying to trouble shoot this for months. No display lights. It has been a solid performer and I hate to replace but haven't found help anywhere. Please advise of a solution if found, Thanks.
  • Anonymous Jul 01, 2008
    Have also the same problem the power went out one night came on and i noticed the display was out on my aiwa.
  • drvegus Feb 04, 2009
    SAME PROBLEM, but my power never went out.
I own a NSX-MT960 and the same thing happen , DEAD DISPLAY.
I just happen to be retired Certified Electornic Tech and Held a FCC first class ticket, and own a tv-vcr -stereo repair shop that worked on all brands,
I had to fix alot of items WITHOUT THE HELP of a schematic diagram and got to be pretty good at it,
THIS HAPPENED about 7 or 8 years ago, but it still may help somebody,
THE DISPLAY IS A VACUUM FLOURESCENT and has a low voltage heater circut to heat it up like old vacuum tube, AIWA PUT IN A SURGE CURRENT LIMIT RESISTOR about a 1/2-1 watt unit with LOW OHMS, I FORGET NOW BUT a 1 watt .5 ohm resistor will fix it, OR JUST JUMP IT for a short time to test, but put that thing back in, better to burn out that resistor than the heater circuit in the display.
HOPE THAT HELPS
RETIRED TELEVISION REPAIR ENGINEER THAT TROUBLE SHOT DOWN TO THE COMPONET LEVEL< NO BOARD CHANGER HERE!!
THAT WAS THEN < THIS IS NOW, NOW YOU HAVE TO CHANGE BOARDS DUE TO SMD WAVE SOLDERING , YOU WILL RUIN A PCB WITHOUT TENS OF THOUSANDS OF DOLLARS WORTH OF DESOLDERING EQUIPMENT.
BEST REGARDS
Posted on Aug 30, 2009
  • 3 Answers
The problem is a fuse resistor. It is on the top, right conrner (looking from the rear of the unit) of the front panel where the display is mounted. It is represented as a solid white line aprox. 3/4" long with a small square on each end. You will have to take out the CD unit to get at this board. Just jumper the fuse resistor with .5 ohm 1/2 watt resistor. Unit repaired. A-Plus Electronics deakon@crosbyironton.net
Posted on Aug 17, 2010
  • Christopher Howard
    Christopher Howard Mar 01, 2018
    Is there a number associated with this fuse resistor? There are several lines with squares as described in that area and none in the very top right corner. And is it vertical or horizontal?
4 Suggested Answers
SOURCE: HOME STEREO SYSTEM CD PLAYER
aiwa cx-na508
Posted on Jul 28, 2008
icdasnoman
SOURCE: Aiwa Stereo
i have the same stereo i got it used and the cd player didnt play cds but i took off the top of it and figured out that there was dust on the lens i cleaned the lens with a cue tip and it worked fine
Posted on Feb 04, 2012
calona_bc
  • 3 Answers
SOURCE: where can i get a free user guide for aiwa cx-nmt520
gm rick hoffer go to this site then type in your model number good luck....http://esupport.sony.com/
Posted on Jul 14, 2012
How do I adjust the volume on a aiwa cx-zht63
It's with neither the left or the right circle, try twisting it to the right for more volume and to the left for less
Apr 16, 2016 | Aiwa Audio Players & Recorders
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
Aiwa stereo system cx ncv58hr which does not display stand by power neither powering up
check if it is connected to the mains, and if the cable is in good order, I'm not sure, if the system has a fuse inside, but perhaps you can check that to. When you can't find a thing. It could be the power supply is defect. (READ THE WORD COULD)
Jan 30, 2015 | Aiwa Audio Players & Recorders
MY STEREO KEEPS TURNING ON AT 1 O'CLOCK EVER NIGHT???
Check with AIWA they might be able to supply the Operating instructions free. Some have them as a PDF on the website.
Dec 18, 2012 | Audio Players & Recorders
Where can i get a free user guide for aiwa cx-nmt520
Jul 08, 2012 | Aiwa Audio Players & Recorders
How do I clear the presets on my Aiwa cx-naj20
Hold down the CD Stop button (the one with the black square) under the display while pressing the power button to the left of the display
Sep 25, 2009 | Aiwa NSX-AJ20 CD Shelf System
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
I WOULD LIKE TO KNOW WHY AFTER PAYING WHAT I DID FOR YOUR ENTERTAINMENT CENTER THAT I WOULD HAVE TO PAY FOR THE REPAIR SERVICE PLAN?????? THAT JUST DOESN'T SEEM FAIR AT ALL TO THE CONSUMER. I WOULD LIKE THE EMAIL ADDRESS TO SOMEONE OF SUPVISOR POSITION. THANK YOU
INSTEAD OF CLOSING THE CD LOADER WITH THE OPEN/CLOSE BUTTON SIMPLY CLOSED IT BY CHOOSING THE TRACT NUMBER WANTING TO PLAY. SO FAR IT HAS WORKED. BUT WILL NOT WORK AUTOMATICALLY WILL TRY PROGM. THE REMOTE NEXT SEE IF THERE IS ANY LUCK WITH THAT PART.
THANK YOU
Jul 06, 2008 | Aiwa NSX-A115 Shelf System
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Aiwa Z-HT65 Shelf System Logo
2,437 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
