Question about Akai PDP4225M 42 in. Plasma Television
AKAI PDP4206 I have an AKAI PDP4206 when turned on the screen blinks a very faint light then nothing happens, no sound no picture. The small light on front stays green. What board is possibly the problem ? Where can I order parts for AKAI?
5 Suggested Answers
SOURCE: Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Posted on Jan 29, 2008
  • 98 Answers
SOURCE: Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Posted on Jun 09, 2008
  • 4 Answers
SOURCE: power light blinks red - tv will not come on
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
  • 52 Answers
SOURCE: VIDEO BOARD
Your tv is going into an error protection mode upon startup. The problem is probably not the video board. When the tv starts, it checks with the cpu to confrim voltages, if a voltage is off or there is a short somwhere, it will prevent the tv from starting up by clicking the relays to power off the high voltage of the tv. The problem could be the power supply, zsus board or ysus. Its hard to say without opening up the back of the set and testing some stuff with the meter, but normally its just a shorted cap, worst case you blew out a fet.. But easy to find if you know what your looking for.
Posted on Aug 06, 2008
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Check to make sure you have the right input selected for the input that ou have plugged into.
Jan 20, 2013 | LG 42LC7D-UB Television
When i turn on my Akai LCT2715 tv the blue screen that says akai appears but disappears sooner then it normally does, then i receive sound but no picture. Even when i change the source (to my ps2 or super...
Use a flashlight to shine light near the screen in a 45 degrees angle when the TV is ON, press menu to see if you get fainted dark video in the background. fainted video indicates that the backlight is defective.
This type of failure could be due to a lower backlight inverter voltage as well.
Check this link for availability.
Let me know if you require further assistance.
Jul 02, 2009 | Televison & Video
My tv screen went black and will not turn on. I
I would look online and see if you can buy a new power cord. That is your problem. that same thing happened to my laptop a few months ago.
Jun 27, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Standby red light just continuesly blinks, no picture -
TV TURNS ON 1-2 SEC SCREEN SHOWS COMPONENTNT1 AND TURNS OFF WITH A POP SOUND FRO9M SPKRS
May 17, 2009 | Akai LCT2701TD Television
TV blinked out and now it doesnt come on?
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Feb 26, 2009 | Akai LCT2715 27 in. LCD Television
Sound but no picture on a akai lct3201td
There could be 2 failures with your TV:
1. The power supply might no be providing 24 volts to the back light inverter board or the voltage is low.
2. If the voltage is normal then is more likely a defective back light inverter board.
The best way to know if you have a back light inverter problem would be to shine the light from a flash light near the screen and observe it from a 45 degrees angle and you should be able to see a fainted image. No image at this point might mean a power supply failure. If the image is there but fainted, then the back light inverter board is defective.
Dec 13, 2008 | Akai LCT2715 27 in. LCD Television
Blinking STANDBY Light front of Television
Hii...
Refere to Sony Blinking Codes :
5 Blinks ===> cause AKB circuit (AKB). Something is wrong with the video. check components on the C board, also check the A board. Also unit be in IK blanking, try turning up screen slightly.
Hope can solved the problem....
[Vrya]
e-mail : be_cek@yahoo.com
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Akai TV troubleshooting
I have the same problem. My Akai 27" flat screen shuts off inconsistantly. Sometimes it will stay on for hours and then we have to turn in on every 2 minutes. It seems to be getting worse. Is there anyone who has found a way to fix this?
Oct 19, 2007 | Akai LCT2715 27 in. LCD Television
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
Akai PDP4225M 42 in. Plasma Television Logo
51 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
