-   We, too, have a DISH connection which is currently off due to a bad wind storm. However, for some reason, the "protect" mode is now on, preventing us from even watching a DVD. What's up?-   tortugagirl
Most systems like this have what is commonly called 'protect' mode. This usually kicks in when the volume is at a very high level, and the unit tries to use more power than its designed for, or it is overheating.
The reason why only this connection has problems and others do not could be a few reasons. One, satellite signals usually carry high quality digital sound, and use more power to play sounds that may be inaudible.
Two, You may also want to upgrade your composite cables to the highest possible quality. (There are many durable gold plated models that work well). Low quality cables could hasten your problem and produce signal bleed.
In addition to this, the unit may cut power when it overheats. Make sure the vents on the unit are not obstructed, and that it is not near other components that are generating heat.
Have Onkyo HT-S580 5.1 system. Can't figure out how to assign digital inputs to input sources....
(More)
Have Onkyo HT-S580 5.1 system. Can't figure out how to assign digital inputs to input sources. Instruction manuel not much help. Have following hookups: DVD Blue ray to receiver- digital co-ax cable; Dish satelite box to receiver- digital optical cable; Blue ray to tv- HDMI; and satelite box to tv- HDMI. Can you help?
I understand that this is the amplifier protection circuitry, any chance I can fix it? I'm sure I'll...
(More)
I understand that this is the amplifier protection circuitry, any chance I can fix it? I'm sure I'll get mugged if I take it to a service center.
i have an active subwoofer, and i want to connect it to the HT-S590 onkyo home theater . knowing...
(More)
i have an active subwoofer, and i want to connect it to the HT-S590 onkyo home theater . knowing that the subwoofer has an rca wire and not a stripped one . how can i connet it and in which hole ?
