Question about NetGear RangeMax NEXT WNR834B Wireless Router
Lost internet connection
I have a home network with three computers on it. I have a dsl modem and a netgear router. The modem was supplied by At&T with my internet service. It was working fine until we got the third computer onthe network and now almost every day (or more than once per day) the internet connection is lost. If I power down the modem and router and then power them back up it fixes the problem temporarily.
  • rlc001 Nov 15, 2008
    One computer is connected wired because it is right next to the router. The other two are connected wireless. The problem started after the third computer was added. It is a new toshiba laptop.
  • Jannette Amandy May 11, 2010
    How is the third computer connects to the network? Wired or wireless? What about the other 2 computers?
    Scholar:
  • 132 Answers
If that Toshiba laptop is not in use do you still experience that problem?
You may change wireless channel in your router.
Do a firmware upgrade for your router as well.
Hope this helps!
Posted on Nov 15, 2008
Keeps loosing wifi signal
Try resetting your wireless router. Power cycle it through.
Symptoms:
lost Internet access on all devices
unable to go online
no Internet connection on router
router Internet LED symbol is amber
To powercycle your home network:
Turn off the router by unplugging it. If you have a modem and router in one device, turn it off then proceed to step 3.
Turn off the DSL or cable modem for three minutes.
Note: Some modems are equipped with a backup battery. If your modem have one, please remove the backup battery to completely turn off your modem. For common cable modems equipped with backup batteries, please see Performing a full reset of cable modem with battery backup
Turn off all computers attached to your network.
Turn on the DSL or cable modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step. One of the indications that the modem have completed its connection is by seeing a green light on the modem. If you have a modem and router in one device, proceed to step 6 after it connects to your ISP.
Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
Restart your computers.
Jan 09, 2015 | Computers & Internet
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
    Is your modem a DSL or cable modem?
    If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
    The DSL modem does not need a DSL filter on the phone line.
    Nov 09, 2009 | NetGear WGR614 Wireless Router
    Home Network Problem with Netgear MR814 and Netgear FS105
    Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
    Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
    Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
    Connect the lan cable from the dsl modem into the first port on your netgear router ..
    make sure your dsl modem is on PPPoE mode so that it autoconnects..
    Now just connect to your wireless router via your pc interface..
    *Do add a network key to your wireless network to avoid unwanted access
    Jan 19, 2009 | NetGear WGR614 Wireless Router
    How to add a netgear wgr614 router to dsl modem
    The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
    Jan 05, 2009 | NetGear WGR614 Router
    How to connect wireless router, Netgear WGR614, to my computer?
    4 steps to set up your home wireless network
    1.
    Choose your wireless equipment
    The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
    Shopping list
    • Broadband Internet connection
    • Wireless router
    • A computer with built-in wireless networking support or a wireless network adapter
    A wireless router
    The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
    A wireless network adapter
    Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
    Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
    2.
    Connect your wireless router
    Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
    First, locate your cable modem or DSL modem and unplug it to turn it off.
    Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
    wireless_chart.jpg Next, connect your router to your modem:
    Oct 29, 2008 | Computers & Internet
    Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
    so your trying to use a dsl router as just a router -dsl with dialup?
    Aug 06, 2008 | NetGear Computers & Internet
    NetGear RangeMax  NEXT WNR834B Wireless Router Logo
    90 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
