Question about Frigidaire GLEQ2152ES Electric Dryer
No heat, shuts off mid cycle
I have a frigidaire front loader dryer, AEQ7000ES, elec.
symptoms are >> No heat > drum is turning > "Ad" error message comes on > dryer shuts down > status lights flash
  • 734 Answers
DEAR FRIEND,ngfam1 here for you!
I am happy to be of assistance!
Do you clean your lint filter every load?
If the vent is blocked it will not get hot either!
Check the outside where the dryer vents out and be sure the outside screen that keeps small animals out is not clogged!
Even half way cloged will stop the drying process!
Other wise this is a situation that you will need to call service!
Now you can call the manufacturer and tell them even though
its after the warranty that you were building a home and not used it till last week!!!
Ask for a supervisor an tell them you did not purchase you stainless steel kitchen yet and must be sure they honer their workmanship first!
I use this for my customers all the time to get things done for them! It will work if you are calm quiet and persistent!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Posted on Nov 14, 2008
    Genius:
  • 3,422 Answers
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
  • Priya darshan Nov 14, 2008
    AD means auto dry.It will check the temp of the clothes so if the
    dryer is quicker than 45 minutes it will shut off earlier instead of
    running the full 45 minutes.
    Also make sure to do a hard reset by unpluging all the cords of your dryer even the power cord for 1 hour and then plug it back in.Turn oon your dryer if you still face the problem then you will have to contact Frigdaire customer support.
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
Ad error code
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Sudden stop
Do you have an error code displayed ? If so what is that. If not the either the door switch is faulty or the control board. More likely to be the door switch but, strange things do happen.Here is the door switch number 134813601. If you need help installing or more info let me know.
Jan 30, 2014 | Frigidaire AEQ7000ES Dryer
Dryer drum stops turning mid-cycle
The belt may be in need of replacement.
Dec 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Affinity Front Loading Electric Dryer. In about 5 minutes of starting the dryer, an error "Ad" shows in the window above the start button. Then the dryer stops and the lights under the "Ad"
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
Mar 04, 2013 | Frigidaire AEQ7000ES Dryer
Frigidaire dryer AEQ7000EGO not heating up
you need to make sure you are getting 220, your dryer will run on 120 but not heat.
2nd check fuse that is located inside dryer near drum
3rd check heat elements for breaks.
Sep 12, 2009 | Frigidaire AEQ7000ES Dryer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
24 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
