I have a p4p800se mobo. I came home from work and the cp was off and would not turn back on. I bought a power supply and changed it out. I also bought to sticks of memmory. When I put it all together and tried to turn it on it will only blink on. After tring many diffent thing I finnaly got it to power up but it will not boot up
    Scholar:
  • 126 Answers
Hello slotdoc,
I have also experienceD this problem myself, same exact thing happened. You most likely had a power outage at your house or a power surge. This often corrupts the system files on the hard drive.
You will unfortunately have to reformat the drive and reinstall windows. I tried everything and this was my only option as well. If you have a problem installing windows your hard drive may have gotten corrupted to the point where it won't even allow windows to install, it will keep hanging up. If you experience this you are better off buying a new hard drive too. Sory for the news, just my personal experience.
Let me know how it works out for you.
Posted on Nov 14, 2008
WHEN I POWER UP ON MY ASUS P4P800SE Motherboard IT WONT START THE GREEN LIGHT ON MY Motherboard IS ON CPU/CHASSIE FANS COME ON BUT QUICKLY POWER DOWN
HI
it is a SMPS problem. SMPS is the main power supply it is also known as smart module power supply..
if you want to check try this link
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
Sep 05, 2011 | ASUS P4P800SE Motherboard
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
How do i change from 32 bit to 64 bit on a asus p5q se2 motherboard
The only way to Upgrade from 32 bit to 64 bit is to buy a 64 bit MOBO and replace it with the 32 bit MOBO.
Oct 05, 2010 | ASUS P4P800SE Motherboard
I need sound driver for my p4p800se mobo ty n advance melts92@gmail.com
Please download these drivers from
http://support.asus.com/download/download.aspx?model=P4P800%20SE&SLanguage=en-us
Regards
Ashly
Feb 02, 2010 | ASUS P4P800SE Motherboard
I have a homemade system with a P4P800SE mobo. The system is about 3 years old and has worked great until the other day it wouldn't turn on. I tried the power switch and the reset button. Nothing. The...
there are many things that can shut down a motherboard.
power spikes, the caps on the board, a blown diode, voltage regulators alot of people use a power strip to protect there computers which is wrong they will not prevent a spike from getting to your hardware, even tho the light comes on the board (3.3v) if you do not have 12v or 5v getting through the board theres no way to get it to go the only thing you can do is see if you can find someone who fix's the boards or upgrade to a new mobo or find a replacment on ebay or one of the other sites
Dec 06, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Emachine 180 (bought 2004)
I have this type of computer (just sitting around , not for my main computer) and I had a smilar problem. I took it to a guy I know (who owns a computer repiar shop) an he said the motherboards on this model go haywire about four years after initial power-up. On mine, it caused the power supply to blow-up (literally) and blew out most components. (Floppy drive, Sound card, USB ports, Keyboar/mouse plugs)
I really don't know if What he said is true, but I replaced the power supply, and now it works fine.
Jul 16, 2008 | E-Machines eMachines Refurbished EMA...
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
E-machine t2682 desktop
cpu setting in good jumper on mobo set on 1 2 pin not 2 3 for reset ? could be bad mobo what socket mobo do uuusse
Jan 21, 2008 | E-Machines T2682 (000002965) PC Desktop
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Computers & Internet Logo
David Payne
David Payne
