Question about Water Heaters
The power vent blower on my hot water tank will not shut off.
I have a State hot water heater tank in my basement. Sometimes the powervent blower motor does not shut off after the thermostat shuts off the burner. It will run continuously. I suspect the pressure switch on the side of the tank is failing. Any help you can give would be appreciated.
  • 2 more comments
  • mzman Nov 26, 2008
    Same exact problem.  Third power vent on my State Water Heater.
  • Anonymous Dec 03, 2008
    these heaters ****.  Replaced control valve and fixed...never geting another State heater
  • GK123 Apr 17, 2009
    Have you found any solutions to this problem?
    I have the same problem recurring periodically.
    GK
    GK
    Scholar:
  • 68 Answers
If the blower continues after the end of the burn cycle it is the cool the heater down. Over running would indicate a defective end cycle temp relay.
Good Luck, Phil
Posted on Dec 11, 2008
Rheem powervent 42vp40f does not provide water to all faucets
Feb 2013
1) Copy following links for Intellivent gas control service manual, low hot water pressure, and crossover:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Crossover.html
2) Unknown if tank has hot water > that is first thing to check.
3) Unknown if air intake screen located under burner is clogged with dust that cause combustion chamber to overheat, tripping FV lockout and breaker TRD glass vial.
Requires removal of combustion parts, replacement of TRD, blow out air intake screen, reset intellivent
4) Unknown if there is error code.
5) Rheem does not post service manuals.
However this unit can probably be repaired.
Feb 05, 2013 | Water Heaters
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 25, 2012 | Rheem Water Heaters
I have a PowerVent residential Gas Water Heater the blower runs continuously and the water is not hot enough
Copy following link for troubleshoot resources, including troubleshoot by type of gas control valve.
Brand and model number of unit is located on label side of tank.
Aug 05, 2012 | Water Heaters
Hi My Power Vented hot water tank vent will not shut off even after the water has reached its temp. I think this tank is 1989.
Water heater and brand are not identified:
Question posted under electric water heater, but electric water heaters are not power vent.
First suspect is gas control valve thermostat.
Or burned points on contactor that turns on the blower.
Check if the burner is still going so you are not getting runaway heating that will trip the ECO and require possible gas valve replacement.
Open following link for older Reliance troubleshoot manual, plus some troubleshooting resources and illustrations, plus link to find age of water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment and say what you did to restore functionality.
Jun 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Basement was flooded when washer inlet hose burst. Approx 6 in of water in the area where the water heater stands. Complaint of no hot water, no pilot flame. Attempt to light pilot successful but pilot...
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Oct 01, 2010 | Rheem Water Heaters
Bosch hot water service 16p burner shuts down
a tankleess water heater doen's have a piliot? but check the vent outside make sure nothing is blocking it, if it detects the exhaust thru the cold air intake it will shut off and over heat, other then that it would have to be the control board
Jun 05, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
1,520 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
