Labtop Brightness Problem
Hello, My laptop screen is very dark. I can hardly see things, because
I accidentually dim the screen and forgot that My Right Aarow key on the labtop wasn't working.
And I need to press FN+Right Arrow key to make brighter again.
So I help on that? any macro? Keys. software will let you reset screens brightness. The brightness on that Video Card software doesn't do anything. I think it was the backlight or something.
Any Help will be great. Thankx, there are brightness control in winvista, but i'm using winxp.
I'm already using the ac power. I:m sure that it was FN+ RIGHT ARROW key I done that before
  • vahn Nov 14, 2008
    HI,again. On-Screen Keyboard doen't support holding FN key on.
    hmmm if you know anything that hacks??
    I can't get that to work with softkeyboards.
    Help
  • vahn Nov 14, 2008
    anyidea how to open medion laptops?
    I tried to open, and unscrews all drivers but
    the laptop still won't open.
    weird. laptop model is MD2900.
  • 4,806 Answers
Plug in a usb keyboard, use the FN key on your laptop keyboard and the curser key on the usb keyboard, problem solved :) you can also use your on-screen keyboard in all programmes, accessories, stystem tools
good luck
Posted on Nov 14, 2008
  • Lee Hodgson
    Lee Hodgson Nov 14, 2008
    reboot the pc with the usb keyboard attached the OS should pick ip the usb keyboard, if it does then the problem should be solved, with on-screen keyboard use the mouse to use the cursor and hold the FN key down on the laptop keyboard, if none of these work try removing the laptop keyboard and giving it a good cleaning, be carefull not to rip the ribbon cable
  • Lee Hodgson
    there are screws under the keyboard, lid and battery, plus the plastics are clipped together so you have to use a very small flat head screwdriver to open it up
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Disply screen has very little brightness
It could be a couple of things. The first is that screen brightness automatically dims when you go on battery, which is to save power. The second is that the brightness setting got changed inadvertently.
There are two function keys at the top of your keyboard that control screen brightness...one turns it up, the other down (they generally have a small circle with rays coming out...one circle is empty, the other filled...sort of like a sun and a dark sun). Hold down the Fn key and press one or the other of those function keys and see if that makes a difference in your screen brightness.
If that doesn't help, you may have a faulty LCD screen.
Hope that's helpful.
Jan 20, 2011 | HP Pavilion zd8000 Notebook
Hello dear sir i have an old samsung labtop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 02, 2009 | Computers & Internet
Screen will not light up
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 04, 2009 | Acer Extensa EX4420-5239 Notebook
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
My screen has dim down and I can't get it back up. I still can see things on it but its dark. Do I need another laptop?
how dim is it so you are looking at it with no lights on if so your screen inveter has faied this is replacable
Jun 04, 2008 | Computers & Internet
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
Monitor too dark....
Usually every laptop has the option of adjusting the screen brightness as you would want the screen to be pretty dim when running on battery to conserve battery life.
First thing to check would be just that.
Dec 11, 2007 | Apple Colorsync 850 Monitor
LCD Display
it might be the brightness in the screen have you tried that? any buttons on the labtop to ajust the brightness settings or it might be that the monitor is going bad.
Nov 24, 2006 | KDS Valiant 671DP Notebook
Computers & Internet Logo
341 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
