Question about KitchenAid 24 in. KUDP02FR Built-in Dishwasher
Kitchenaid dishwasher - soap dispenser will not open
Hello -
I have a KitchenAid dishwasher a few years old. Model number KUDL02F4SS4 I bought at Lowes. The soap dispenser door stopped opening. There is nothing blocking it. I have searched your site but I have not found a resolution to my problem. I can fix it myself, I just need a manual and a little guidance!
Thanks.
5 Suggested Answers
  • 21 Answers
SOURCE: KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Posted on Apr 09, 2009
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
  • 1073 Answers
SOURCE: Kitchenaid dishwasher leaking from door
remove the outer door panel close door and see where the water is comong from look at the round vent in the door area
Posted on Apr 30, 2008
jsrock516
  • 5911 Answers
SOURCE: KitchenAid Dishwasher (model KUDS01IJBL) has black gunk inside
That black gunk is caused by soap deposits and food particles that do not get washed down the drain. This all collects in the area around the door gasket and front of the wash tub and forms a sticky black sludge. You need to periodically clean the interior of the dishwasher out with a non-abrasive cleaner with some bleach in it to kill bacteria. You should also check the wash pump sump (located under the lower spray arm) to make sure it is not being clogged with food and debris. In order to access the pump sump, you will need to perform the following:
1. Remove the lower wash rack and lower spray arm.
2. Remove the upper wash rack and spray arm.
3. Locate the screws holding in the upper spray feed tube. Remove the screws to the feed tube and turn the whole assembly 1/4 turn to the right (CW direction). The entire assembly will unlock from the wash pump assembly and lift out.
4. Remove the strainer assembly (known as an accumulator) that covers the pump sump area.
Inspect the sump area for food particles and debris that may be contributing to the mess inside the wash tub. If you need some guidance, pcappliancerepair.com has some very helpful exploded view diagrams to assist you.
If you have any questions, or require further assistance, please let me know. I hope this is helpful to you.
Posted on Aug 17, 2009
Kitchenaid dishwasher soap dispenser will not open during cleaning cycle
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 24, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
The soap dispenser does not open completely during the cycle. We are using pod soap and it is just stluck in the partially open dispenser and the dishes are dirty.
Most KitchenAid dishwashers have an adjustable upper rack, since I do not have your model number I cannot advise on specifics but if you move the upper rack to the higher position the dispenser will open a little further.
Also if you are not washing well on the upper rack you may have either a plugged spray arm or sump.
Look at the spray arms close, if the holes are plugged then it will not spray into the dispenser properly.
If you have a tall tub KitchenAid then the sump may need cleaned. Here is a link to instructions that might help that. But not knowing your specific model these instructions may not apply
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 25, 2010 | KitchenAid Dishwashers
Dishwasher starting to leave soap film on dishes. It is a 2 year old Kitchenaid. Cleaned filter, no changes in our soap or water.
First check the salt dispenser located at the bottom of the machine under the bottom rack,make sure it is full,then also check the rinse aid dispenser is full and adjusted correctly,in the rinse aid dispenser it will have numbers turn the dial to about number 2 this is average
Dec 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
The detergent door doesn't open
Please reply your exact model number so we can see what the door looks like.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid 24 in. KUDP02FR Built-in Dishwasher Logo
378 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
