Question about LG Studioworks 57M Monitor
Moniter back on whack!
Hello everybody,my monitor suddenlly starts flickering & goes blank although the green power light stays on,if i give it a gentle whack!! every thing becomes ok for sometime;i hav recently updated my monitor & display adapter drivers..i hope u can help me.
    Scholar:
  • 119 Answers
Sound like you have bad solder connections, sometimes the break is so small they can be hard to find. Unplug the unit for a short while & take it apart to look for bad connections, most likely they will be on the main board. Monitors have more shielding ( to remove interfearance) so it typically is a little harded to repair a monitor than a tv. good luck
Posted on Nov 20, 2006
SOURCE:
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Problem with moniter
i have BENQ lcd 15" monitor, the problem is that the menu appear atomaticaly
Aug 25, 2008 | BenQ FP71G 17" LCD Monitor
Blank Monitor
Try your monitor on another computer, just to make sure it's the monitor and not a video adapter problem in the computer. It may be possible to fix it if you can find a reliable computer or TV service shop nearby. However, the cost may not be worth it for a 2-year old monitor. Unfortunately, the best solution is probably to buy a new one. : (
Jan 13, 2008 | Computers & Internet
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
LG Studioworks 57M Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
