Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher Paykel Replace Lid Actuator
Recently received the F1 code and found my top drawer is not sealing, ordered new lid actuators. Wondering if there is any special trick to the replacement, such as adjusting or time savers?
Thanks
  • dobbsbrown Jan 19, 2009
    Hi, I've just posted something very similar!! Very keen to fix this ourselves. We need to replace the bottom actuators but can't figure out how they are removed or replaced.
    cheers
    Sarah
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
vitg55
  • 78 Answers
SOURCE: Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Posted on Dec 01, 2008
  • 3247 Answers
SOURCE: Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Posted on Nov 10, 2009
  • 19 Answers
SOURCE: Fisher Paykel DD603 both drawers are leaking F1
Change your detergent, high foaming detergents leak through the overflow, highly unlikely that both drawers developed a leak at the same time.
Posted on Dec 09, 2009
  • 552 Answers
SOURCE: I have a fisher & paykel dd603 double dish
Fisher Paykel dishwasher repair video, this video will walk you through repairing your dishwasher.
http://www.appliancerepairlesson.com
Posted on Feb 26, 2011
How do I move the actuators by hand on a Fisher and Paykel DD603 two drawer dishwasher
Lid motors should rectify themselves when power is restored. Once they have moved up then push the drawer back. If they don't rectify, you can disconnect the actuator from the side frame and rotate the actuator to wind it up.
Apr 28, 2016 | Fisher and Paykel Dishwashers
Fisher and Paykel Dish Drawer: I flooded it by using wrong soap. It was flashing F1 but I solved this by drying it out after removing the bottom drawer. That problem is solved but now the top drawer is...
Most likely the lid seal is dislodged and is obstructing the bottom drawer. Need to manually operate the lid seal actuator yoke and motor to bring the seal back to normal position. Can be messy.
Will need to get the bottom drawer out from housing and work on lid seal assembly located in the main housing.
http://spares.bigwarehouse.com.au/images/files/6145_5635c632f6805f5644d3f35b6feea5bc.pdf
Sep 25, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel drawer stuck closed how to fix.
Turn the mains power off and force pull the drawer slowly.. No jerky movements. The lid seal is stuck. Once open, check for any damage to lid seal by running fingers on the underside of the top of cabinet where the drawer slides in. Turn mains power back on. If the drawer does not slide back in then it is likely the lid seal actuator motor is stuck or power to motor has failed. Will need technician involvement to fix. If lid seal looks torn then it will need to be replace. Can cause leaks and further faults otherwise.
Apr 09, 2013 | Fisher and Paykel 24 in. DS603H I Built-In...
Fisher paykel dd24scx6 lid fault
This error is linked to the mechanisms that operate the lid seal of the drawer.
If the drawer feels hard when moving in and out, then the lid seal could be stuck in close position and the movement actuator motors may have lost power.
If there is no change in the situation after turning off the mains power and turning it back on, then there is a component failure linked to the lid seal.
Will need a technician to fix it if you are not very familiar with fixing electrical stuff. The lid seal actuator assembly is very complex. The easiest to fix is a failed power board under the drawer and the hardest is to replace the actuator motor if it has gone faulty.
Mar 27, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Water leak from top drawer. Had F1 flood alarm
Top right corner: it means the bad right actuator could not pull down the lid seal on that side causing a leak. The actuators are sold in pair. They are not expensive. Replace both of them when you order them in. Need to inspect the rubber seal around the top lid since if it is distorted another 60 bucks to get a new lid for replacement also. The new lid comes with the york to engage with the actuators.
May 08, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Flashing F1 code, how do I fix
F1 code is water leaking. 1- Dry out the bottom housing to make the F1 disappear. 2- Replace Actuators and the lid seal to prevent this happens again. The actuators is pulling down from the left and right sides to hold the top lid against the top surface of the tube groove to seal water from coming out during the wash cycle. When actuators are bad, they can not hold the lid down or make the lid tilted to one side hence the leak is coming. When the lid is tilted for a long time the seal is distorted then it has to be replaced since it is out of tube groove shape
Dec 11, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Bottom drawer of dishwasher is jammed and stiff..cannot close...as well soap dispenser is stiff...what to do
The lid is pulling down by either left or right actuator causing the lid seal touching your tube. In running mode these 2 actuators pulling down the lid to seal the tube so no water leaking. When the cycle is completed, the actuators push the lid up. In this case one of them is bad not pushing the lid up. The actuators are not hard to replace. When you order, it comes with a pair, replace both. Inspect the lid, if the seal is damaged, you can order the lid to replace together.
Oct 24, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel No power to bottow drawer
the board you checked has the sensor have you removed and dried off both of them? and check the actuator motors that hold the lid down these fail causing the F! due to the lid not sealing tight'
May 08, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
1,050 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
