Question about HP Compaq Presario 2200 Notebook
Compaq presario 2200 screen stay dark
Upon initial boot the compaq logo is just barely visible after that the screen stay dark.  Attaching an external monitor works fine.  No hardware errors are present.  The machine has not been dropped or damaged in any way.  Symptom "just arose" during  a boot up. Battery ad charger are fine.
Is this perhaps a video invertor problem?  If that is possible is there any way to test to be sure?
  • HP Master
  • 4,806 Answers
Sounds like the inverter has gone, the only way to test this is to remove the laptop lid, remove the bezel (front plastic cover) please take care not to crack or splitt the plastics, then get an electical tester and test the inverter coil to make sure a current runs through it, if it doesn't its the coil, if it does you need a new inverter, the coil is located under the plastic sheath
good luck
Posted on Nov 14, 2008
How to let boot screen show on external monitor
Press Fn key and hold, now look for the icon that shows laptop and monitor screen on the top F keys and press this will switch to external monitor.
May 27, 2012 | Compaq Presario Computers & Internet
Thanks. Compaq Presario F761 US: When I hit the power button, it comes on for a split second. That's it. Help.........
I'll give you something to try :
using a bright light florescent ,lcd, etc. shine it right on the screen. Look in the center of the screen for the windows logo (might be barely visible).
If this is the case, you either have a bad inverter or the CCFL in your lcd panel is bad. If it is, re-post and we can walk you through troubleshooting or replacement.
Aug 31, 2011 | HP Compaq Presario F761US Notebook PC
When i try to boot it up, the monitor, keyboard, and mouse don't
sounds like you have a failty motherboard/cpu a replacment my be an ideahope this helps if it does please rate this answer
May 12, 2010 | HP Compaq EVO D51S Intel Desktop PC -...
So, this is a Desktop unit. My advice is this; Take the cover off and try to dust off as much webbing inside as possible.Make sure you take off the power cord when working inside. You will see a fan near the middle of the motherboard. This is your Heatsink/Fan for your CPU. I would bet many pennies this is overheated and may not boot again and if it does it will be unreliable. With your fingers and everything out of the way, plug the bare unit in and turn it on. Make sure the fan on top of the CPU is running. If not, quickly shut it off. I will help you more as you write back and we will get it running.
Mar 21, 2010 | HP Compaq EVO D51S Intel Desktop PC -...
Cannot boot up normally the screen stays dark, but clicking esc when powering up and continuing with f1 does work. why?
Sounds as though your drive boot setup isn't right check in BIOS. F1 is the classic "Continue" after problem encounter key. The Esc, allow you to override and continue.
Feb 05, 2010 | HP Compaq Presario 2200 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
My screen is extremely dark. barely visible. external monitor works ok.
You probably have a bad LCD panel back-light. Time for the repair shop. Probably not worth repair though. Unless you have warranty or extended warranty.
Could also be an inverter board ... which supplies the high voltage for the back-light.
Nov 22, 2009 | Compaq Presario M2000 Notebook
My Compaq Presario v2000 will turn on but the screen is just black what do I need to do to fix it?
Can you see any image on the screen in a dark room, using a flashlight sometimes helps. An image will be most visible right after you turn the laptop on, when the logo appears. If you can see the image but it is dark you need a new probably backlight inverter which is a relatively easy and cheap repair - I usually charge less than $50. JC Hunter
Nov 13, 2009 | HP Compaq Presario V2000 Notebook
HP Compaq Presario 2200 Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
