Question about Mitsubishi WD-57732 Projection Television
I have a wd 57732 and want to replace just the lamp, how do i take the housing unit off? and is it safe?
    Problem Solver:
  • 4 Answers
Hi! It's perfectly safe! Just be sure to always wait an hour or preferebly more before doing this, and unplug the tv! On a DLP tv such as this there is a hatch with two phillips screws holding the cover on for the bulb assembly. Remove them 2 screws. Remove the cover and you will see two thumbscrews that may need extra help from a screwdiver as they may be too tight. Now put on a pair of vinyl or rubber gloves and pull the lamp cartridge absolutly straight out with no twist motion!. Glass lamp section will potentially fall if you do. Place the cartridge on a flat surface and find the 3 tabs on the lamp unit and carefully pry them off. Inside, take out the 4 screws and the mounting brackets holding bulb. At this point you can clean out dust inside the lamp box. Next take out the old bulb, put the new one in (be sure to use the gloves installing new bulb or else any finger oil will cause the bulb to fail when it gets hot) and reverse steps to close.
Posted on Nov 14, 2008
2 Suggested Answers
SOURCE: mitubishi WD-57732
I'm assuming that you already have the housing out of the TV. If not remove the lamp cover panel (two phillips screws), Locate and unscrew the two chromed flat blade screws that hold the module in place and gently pull the housing out. Now locate the three locking tabs on the housing. There is a large one on the bulb face side, and two smaller ones on the mesh screen side near the handle end. Using a thin bladed screw driver, slide it under the curved edge next to each of the small tabs and gently pry up to pop the side cover off of the tabs. Rotate the back cover (three sided) so that the small tabs come clear of the rectangular holes in the cover. (It should pivot on the third tab). Now use the screw driver to gently pry the U shaped clip off and over the third tab. Once all three tabs have been released the back half should just slide back and off the front half. Reassembly is basically just sliding the back cover back on until the tabs lock into place. While the bulb is out blow all the dust out of all THREE screens (there is a small one next to the greyish metal plate).
Replace the bulb by removing all the internal screws necessary to release it from the housing, noting how everything goes back together, including which wire goes to which terminal (If your bulb does not come with new wires you'll have to swap them to the new bulb), and where the "UP" marking on the bulb goes. Drawing a picture or better yet taking a few pictures is a good idea. When installing the new bulb do not touch the bulb with your bare hands (use latex gloves). Supposedly the skin oils can cause the bulb to fail prematurely. Finally make sure that the wires do not touch the bulb and are as far away from it as possible after it is back together, if necessary open it back up and bend the wires to reposition them.
Posted on Dec 21, 2008
My replacement bulbs keep burning out within 30 days. I took a closer look and there is a small square piece of glass that sits next to the lamp housing. It looks as if the light from the lamp goes through...
Something is definitely wrong if you are consistently only getting a month out of a bulb.
Either something is overdriveing the power to the bulb (unlikely) or there is a vibration or something is intruding on the bulb itself.
Good luck and let us know what you find on this.
Jan 08, 2015 | Mitsubishi WD-57732 Projection Television
Replacing Light bulb w/housing
Lamp is replaced by customer in most cases---look to owner manual---in general if lamp up front (I think yours is by the model number indicated) the front plate beneath the screen gets removed (have set unplugged) and a lamp door is marked---it opens when screw/s securing it are removed.
Inside are two more screws---with them removed grasp the handle for the cartridge with the lamp and pull it out.
Be sure to get a Mitsubishi lamp and not a generic "bulb" which would require you to take the housing apart---generic bulbs have a much shorter life.
carefully slide the replacement in so the two pins on the rear connect correctly into the socket in the set where they go.
there are video instructions for many sets on You Tube.
Jun 01, 2012 | Mitsubishi WD-57732 Projection Television
I have a Mitsubishi WD-57732. The problem started
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp)
(Lamp-Enable goes to DM but not to Ballast) It's related to the lamp.
Mar 26, 2010 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-57732 LAMP continuously burns out. I have replaced four in two years. We don't watch alot of TV.
There are a few issues here:
The lamp you are purchasing could not be OEM, or a compatible lamp--OR you have a ballast/power supply issue blowing the lamp out.
The original lamp is manufactured by Osram, but a better and compatible lamp would be Philips, who pioneered the lighting for DLPs. The ballast needs to be compatible with the lamp and Mitsubishi ballasts are compatible with most lamps, but work best with Philips and Osram. Only buy from an authorized dealer!
Feb 04, 2010 | Mitsubishi WD-57732 Projection Television
Dead lamp
The sensor is located on or near the lamp compartment on the back side. If your lamp keeps blowing it may be the lamp cooling fan not working. However are you sure the lamp is blowing? Press menu and device on the front control panel both in together for 5 seconds and see if the led blinks a two digit code, then let me know the code. Please respond to this same post.
Jul 08, 2008 | Mitsubishi WD-57732 Projection Television
Dead lamp!!!
is it tha lamp cracked? are you using original lamp from mits? i founded people using aftermarket lamps with other specks this lamp is 150 watts ,this info its going to help.
if components on the Power board K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects are a deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010 let me know if you need anything else
Jul 04, 2008 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-57732 Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
