Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi Diamond blinking green light of death
Your fix paper is no longer posted at http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair. Can I get it?
Thanks,
Michelle
Model # is actually WD-62825
  • 3 more comments
  • Anonymous Jan 22, 2009
    blinking green light, what power on
  • Max1004 Feb 05, 2009
    No power button work on remote or tv so I tried resetting it as the manual said but I get the green blinking light then nothing. The remote power or the tv still doesn't power on. Please help.
  • anyknight Feb 17, 2009
    Green light continues to blink. I used to be able to reset it and it would run for a little while, not even the reset button doesn't do anything. The green blinking light simply returns...HELP PLEASE...
  • Anonymous Mar 02, 2009
    my sheeit is just blkink and wont stop mayne.. im like wtf mayne.. how do you fix this joinstky bra
  • Anonymous Apr 05, 2009
    wd52825 blinking green light = no tv please help
  • 3 Answers
Try going to tvrepairworld.com located in NC. Inquire about their dm26 kit with cd!
Posted on Jan 26, 2010
  • jgreens1264 Jan 26, 2010
    try going to tvrepairworld.com located in NC. Inquire about their dm26 kit with cd!
I need help with my wd-52525
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
May 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS 55809 Rear projection TV
replace DM
Picture of bad caps
Jan 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi fix.....
replace DM
Picture of bad caps
Jan 13, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi rear projection tv won't turn on
know problem of bad caps.
replace DM
Picture of bad caps
Jan 08, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Green vertical line on the left side of TV
replace DM
Picture of bad caps
Dec 28, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Please send capacitor replacement info
replace DM
Picture of bad caps
Nov 01, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Green power on light flickers
You may need to repair the DM board, do you have any solid state repair experience? Check this out, it is already posted here! http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good Luck to you!
Jul 30, 2007 | Mitsubishi WS-48313 48" Rear Projection...
Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Jul 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi diamond series tv
I have a 2003 mitsubishi WS-55711. While watching TV the other day it just shut off. When I pressed the power button, the green light turned on for approximately 3 secs, then shuts off. I've attempted to simply unplug it for a period of time in hopes that it would possibly reset. However, the same thing happens. Is this a problem I can fix on my own or does a professional need to fix it? If I do have a pro fix it, what is the likelyhood that it will happen again? Should I just invest in a new TV? Thanks
Jun 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
1,281 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
