Question about Kenmore 22062 Top Load Washer
Kenmore 22062 will not cycle correctly
I have noticed that when it starts the soap disp gets water then the washer drains and then sometimes it dosent add water and tries to wash with no water. It does this on all cycles of wash. Sometimes it sticks on drain and spin for long periods of time. I also get SL and LD codes at times. The water sounds to drain out good but then sounds to run dry. If i put it on extended spin only it runs water in and dosent spin out. Sometimes in the past week it would seam to run correctly.
  • Anonymous Jan 12, 2009
    washer will not cycle correctly.
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Posted on Nov 15, 2008
Error code f35
F35 (on some models)
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
Apr 19, 2011 | Kenmore Elite HE5t Washer
I am getting a f-35 code on the washer ..what does that mean?
F35
Check if the air trap is not blocked.
WASH CYCLE)
Check drain pump.
Item 20
$86
Mar 17, 2011 | Kenmore HE2 Plus Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer quits during cycle
That is a SUDS LOCK. Open the front panel to access the drain pump filter. Clean it out. Run several cycles without any detergent to clear out the soap being retained in the washer. If you are not using H.E. soap, switch to it. Use the amount of detergent specified on the package. Front load machines will not work correctly with excessive soap and the laundry gets no cleaner with more soap.Also use high water levels not medium or low. Use hot water whenever possible to reduce the suds residue.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting f2 signal on kenmore elite quiet pak he3t
F2 and F02 error are one and the same. My daughter was doing a load of towels in my Kenmore Elite HE3t front loading machine, when I went back to put them in the dryer the washer had a load of water in it and an error reading of F02. Checked the manual Could not find anything wrong with the Drain Hose?
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display.* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
May 06, 2009 | Kenmore Elite 45986 Front Load Washer
Washer wont wash displays LD on display timer
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Dec 28, 2008 | Kenmore 22062 Top Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader
There are little holes for the liquid to release form in the cups.
Check that the holes are not clogged!
Sep 02, 2008 | Kenmore 22062 Top Load Washer
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Jul 19, 2008 | Kenmore 22062 Top Load Washer
Kenmore dishwasher has never cleaned dishes
make sure you are getting plenty of water. Start the D/W without putting soap in disp. run for about 1 minute, Make sure there are no suds inside. If there is, run full cycle to get excessive amount of soap out. If no suds check in pump resevoir to make sure its not clogged.
Jan 05, 2008 | Dishwashers
Kenmore 22062 Top Load Washer Logo
147 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
