Question about Philips DVDR3576H DVD Recorder
Dvdr3576h will record on dvd+r but will not play on other devices
We are using lightscribe dvd+r disc. The discs are obviously recorded on but will not play on other devices. How to make these discs compatible is somewhat confusing.
  • Anonymous Apr 29, 2009
    I had this same problem, the solution worked for a few discs. Unfortunately the last two discs I finalized aren't recognised in the unit or anything else.
  • 8,596 Answers
You will need to finalize the discs on the Philips. I know the manual says that +r may auto-finalize, but I found that finalization sometimes fails on the first attempt. Go into the menu for the Philips, and select the Edit Disc -> Finalize option. Once finalized, your disc should play in other players.
-Tha Mp3 Doctor
Posted on Dec 25, 2008
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
All of my recorded discs are DVD-R. Will the Toshiba DR420 play DVD-R discs?
Yes,it well play on Toshiba and all other brands of the DVD Recorders.If your DVD- R discs do not have any finalizing codes in the orignal recording device u use to record it.
May 28, 2010 | Toshiba DR420 DVD Recorder
I taped 8 hours of programming in LP mode and want to burn it onto disc. Can I use the divide title mode to split the title into 3 segments so I can fit on 3 discs?
Yes, go into hdd list of recorded shows and select show
edit, chapter mark, find about 1/3 of show, select mark,
yes, back 1 menu under chapter mark is split or cut,
just select and you now have 2 files, 1/3 of show and 1 2/3 of show, just repeat, for 3 parts. and burn to dvd.
Jan 07, 2010 | Philips DVDR3576H DVD Recorder
My Samsung DVD-HR753 will not recognise any of the blank discs I am using including DVD-RW. I've tried Panasonic, Logitec, HP Lightscribe and Datawrite but no joy. I'm trying to record from the HDD to DVD....
It looks to me to be an old machine as I see listings for that model in 2006, now there could be a few reasons firstly it may need a firmware update which will enable it to "recognise discs" made later than it (service engineer).
The laser may be poor, playing is less stressful than recording or it may need a general service, their mechanisms and/or optic slides get dusty sticking to old lubricant slowing response times so the machine goes into "timeout" or just gives up, some have rubber belts which stretch.
It comes down to cost of repair versus new one? you could try a lens cleaner disc (a disc with a bit of fuzz stuck on it) but I have found these have varied sucess and a service clean is better with a suitable liquid.
Hope this helps.........
Aug 28, 2017 | Samsung DVD-HR735 DVD Recorder/HDD...
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Discs will not play on any other machine
I have the same problem with a brand new HP Pavilion PC running Windows Vista with a LightScribe DVD reader. I downloaded the latest driver from LightScribe, but the system refuses to recognize it. A request for help from HP hasn't been answered yet.
My son has the same problem with his custom machine running Windows XP.
Aug 24, 2008 | Sansui VRDVD4005 DVD Player/VCR
"unknown disc, please, check disc again
this happens all the time on my dvd player. im just about ready to throw it out the window. ive only had it awhile.
i called customer service. they said you need a dvd cleaner to clean the lens. I bought one called dvd dr laser lens cleaner. unfortunately, it rejected that disc as well. you could try it i guess, but good luck. tell me what happens. in the meantime, i'm going to put this piece of garbage up on ebay or throw it out my window. total waste of 300 something dollars. buy the warranty! i didn't and im paying through the nose.
i payed $80 for a new laser about 2 years ago, it did JACK. so, dont do that either. sorry to sound so aggravated, but i have been working on this for a few hours now. i opened it up and tried to look at the lens. looks fine. good luck.
May 25, 2008 | Zenith ZRY-316 Video Recorder
Goodmans home dvd recorder
Make sure the DVD has been finalised. When you finalise a DVD the recorder puts all the disc content information at the start of the disc so that any device you put it into can find out what is on the disc without scanning through 4.7 Gigs of data, (which would take so long it would drive people mad everytime they put a disc into anything). Because the table has not been written the PC cannot see what is on the Disc.
Another possible answer: some makes, Orion for one have a Virtual Record mode that it was not possible to play in any other device.
And Orion do make products for Goodmans.
Most likely the first answer though.
Feb 17, 2008 | Sony DVP-NS530 DVD Player
Philips DVDR3576H  DVD Recorder Logo
264 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
