Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
No picture with a thumping sound
I have a JVC projection TV 56WP74. Turned it off, then when turned back on no picture and only a thumping sound. TV wont turn off unless unplugged. Any ideas?
  • unibigoshmon Mar 15, 2009
    I have the exact same problem! Have you figured it out yet?
premtech
  • 934 Answers
SOURCE: JVC AV-56WP74 projection TV green sagging and can not be adjusted out.
The convergence amps need to be replaced. If you're having a shop do this call around and ask what they charge for repairing the convergence. If you're doing this repair this set uses two stk392-110 Sanyo built amps. You will also need to test and possibly replace one or more of the 1.5 ohm feed resistors in that circuit.
If you're doing this at component level try Acme in Florida for amps and resistors: 1-800-575-9833 http://www.acme-sales.net/index.shtml and if you're doing this at modular level send it to PTS http://www.ptscorp.com/ 1-800-844-7871
Bill
Posted on Nov 27, 2007
  • 12 Answers
SOURCE: JVC AV-48WP74
havent had time to check these things out but here is some raw research I have done
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Posted on Dec 06, 2007
  • 12 Answers
SOURCE: JVC AV-48WP30 48 in. Rear Projection
this is the raw research for this that I have found. It seems like the most likely culprit for this is the stk chips on the convergence board (JVC didn't put nearly enough heat sink compound on should be a small layer all the way across they put on a couple dabs) I hear tale you can check this out by disconnecting the convergence board and turning on the set . only go after the convergence board from the front (behind the speaker grill is another panel, the convergence card is right behind there) there is a sneak circuit which will kick in possibly destroying at least the dvi input and mabie more if the set is powered on with the back removed and you didn't put a jumper in the right place or cover over a hole in the back of the dvi module (supposidly to keep people from hacking movies, like there arn't easier ways to do that if you really wanted to). if that doesnt fix it then I have found several other possibilities but I am now a few hundred miles from the tv that I was working on so havent had a chance to try this out:
(508)695-7302
(508)695-7769 FAX
Perry Bower
Electric Medic
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Symptom:
Solution:
SB connector
SOURCE: no sound on my 52in jvc tv
i unplugged my tv and when i turned it back on had picture but no sound and all cards are still in tack.
Posted on Sep 04, 2008
SOURCE: no sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Posted on Dec 15, 2008
I was watching Tv and my tv went out and start making a thumping nosie, what could it be?
Mine is doing the exact same thing. Was wondering if you had gotten any good advice yet.
May 23, 2010 | JVC AV-56WP74 56" Rear Projection...
AV-56WP74
Check all of the large resistors on the convergence board. Usually at least one will be fried. Most likely, the 2.2 ohm if I remember correctly. Of course, make sure all the plugs are correct and plugged in.
Apr 21, 2010 | JVC AV-56WP74 56" Rear Projection...
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
Our JVC 56in rear projection tv cut off and when we tried to turn it back on is makes a thumping sound and the blue light on the front blinks and the thumping sound gets louder... Help??
The problem is one of the video drive IC's on the crt boards is bad. These IC's are located behind the front speaker grille. The board connected to the bottom of the crt's will have these ic's on them. They will be screwed into a metal "heatsink" The part number is TDA6111Q
Nov 28, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC 56in. is broken
id probably get a new model once they are past the 5 year mark its about time for a new one
Jul 22, 2008 | JVC AV-56WP74 56" Rear Projection...
Ctc 195 series rear projection T.V. piture quality
Can you post a picture of what the video is doing? It shounds like a pincushion problem, but it may be convergence amp as well. A picture could clarify it for me so I would know which direction to assist you in.
Feb 23, 2008 | JVC AV-56WP74 56" Rear Projection...
Blue screen
convergence ic and resistors require replacement and that you need to check for cracked solder.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 28, 2007 | JVC AV-56WP74 56" Rear Projection...
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC 56
Look in manuel for convergence setting and reset. This happens if your set has been moved lately or shaken adbruptly.
Oct 03, 2007 | JVC AV-56WP74 56" Rear Projection...
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
