Question about iRiver H10 MP3 Player
IRiver MP3 Player Not Inisializing
Hi, I have a basically new H10 iRiver and it has been working quite fine until last night. I went to turn it on and it comes up and says "initialising, please wait" and then it just sits there for even 30 minutes or more. I tried reseting it with the reset function but same result. Then I tried plugging it in to the PC but it just said "no connection made" etc. Can somebody please help??
If you haven't already I would try an emergency connect. -First perform a standard reset as you did before (press rear button for 20GB or disconnect & reconnect the battery for the 5/6GB versions). -Leave the unit turned off, but connect it to your computer's USB port. -Hold down the "o" button and then press the power button for a second to power on the device. -Do not release the "o" button until you see a message such as "emergency connect" or "mass storage" on the player screen. I beleive the message has changed with firmware versions, but it should be something similar. -If this works it should be detected by your computer as an external drive. You should have access to the files. -I would remove all music files from the device and then use the iriver plus software to restore system files. -If you manage to get to this point I would install the newest firmware available for your model of H10, found at the iriver site. The newest firmware adds a lot of functionality, speeds up player response significantly, and fixes many bugs as well.
Posted on Jan 23, 2007
SOURCE:
My h10 won't start anymore!
My I river H10 won,t start after purchasing a new battery for it.The charge light on the charger is dim
Nov 24, 2012 | iRiver H10 MP3 Player
Vista will not recognize iRiver H10 MP3 player
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
Jan 08, 2009 | iRiver H10 MP3 Player
I need to restore the system files for my H10 Iriver MP3 player
go to www.iriver.com people - what the f--- do you think it means?
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | iRiver H10 MP3 Player
H10 20gb-hot and won't turn on
Heat = bad = kills electronics. Every Mp3 player gets hot when you use it, but some get unreasonably hot because there is a piece of defective hardware.
Try the soft fixes first though - remove and reinsert the batteries, check for firmware upgrades from iRiver's website (their site is full of good information), and use any repair/recovery tool that IRiver suggests.
Most likely, though, this Mp3 player is seeing its last days. There is no repair service for such a problem that would cost less than a new Mp3 player.
Nov 01, 2007 | iRiver H10 MP3 Player
Iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Mar 28, 2007 | iRiver H10 MP3 Player
IRiver H10 Problem...
Hard drive finished.
The iriver usses the Microdrive, which is a piece of sh...
I wonder can replace the Microwith the Compact flash.
Ipod mini & Creative can use Compact flash
Apr 09, 2007 | iRiver H10 MP3 Player
Touch pad stopped working.
Unfortunately no there is not. These players are basically disposable. If your out of warranty then you should get a new one.
Oct 31, 2006 | iRiver H10 MP3 Player
My h10 will not switch on, iriver support will not help
Try to reinstall the software CD you received with the player. Good luck
May 01, 2006 | iRiver H10 MP3 Player
Iriver h10 20 gb hangs quite often
it is not recommended to initialize while synchronising this will fry a couple of circuits inside
Feb 03, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
101 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
