3 plugs inside the tower came unplugged - Computers & Internet
  • Anonymous Nov 14, 2008
    foxconn
  • Andrew Bestic May 11, 2010
    Which plugs are you talking about?
    - The plug that connects to the back of your computer, from your power outlet
    - Something inside the computer case
    - Something else?
  • 4,806 Answers
Sounds like the molex power plugs that plug into ata hard drives and optical drives, the only other thing is they are not in use
Posted on Nov 14, 2008
Alsowhere do all the cords go inside the tower... i h
as much as i want to help you, there is too many cables inside a computer and i dont know which one your referring. as you said everything is unplugged we can make it work but that is complex discussion to start with
Feb 28, 2014 | Compaq Presario 5BW284 (202493-003) PC...
When I turn My Computer on all that happens is I hear the fans on the back running really loud and a light on the back flashes green. The light on the on button on front doesn't even come on, but I know...
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Nov 08, 2010 | Gateway GT5220 PC Desktop
How to open the tower
Unplug all of your cords going to the tower, just for a safety factor. At the top of your tower, at the back you will see a latch, pull that latch and the side of the case will release, take the side of the case off and there is the inside of your computer.
Oct 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Smell something burning inside Dell desktop tower.
Is the computer under warranty? If so, take it back.
Otherwise, open it up and follow your nose - find out what burned inside it and try replacing that.
Mar 09, 2010 | Dell Dimension E510 PC Desktop
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
Xps 600 tower does not power up the monitor
The system will turn off if you hold down the power button for 10 secs. Can you check if other monitors work fine with this system?? (my best guess is - NO) since this monitor works well with other systems, the monitor being a failure is ruled out. So this boils down to a system failure & not a failed monitor. Worst case scenario this one must be a Motherboard & Power supply issue.
Jan 12, 2009 | Dell Microsoft Windows XP Home Edition
Compaq presario sr1115cl wont power up
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Jul 01, 2008 | HP Compaq Presario SR1420nx...
Card Readers have disappeared
Don't believe the manufacturer when they say that the only choice is to reinstall - Your question of "what if they disappear again?" is valid, because it could very well happen.
Go into the Device Manager. Make sure that you can see hidden devices, and try to "refresh" the system. There should be a small button in the top pane to do this with. If you get no results, try going down to "Disk Drives". This is where the card readers SHOULD be showing up. If you don't see anything here, then you most likely have a hardware issue. Try once more to refresh for good measure, and to see if your computer can find them.
If you are comfortable with the inside of the machine, open up the side panel, with the power cable unplugged and the switch on the power supply flipped to the "O" side. Carefully follow the cables from the front panel where your card slots are to where they plug into the motherboard. Ensure they are properly plugged in.
If everything looks alright, you may have an issue with the hardware, either the slot device itself or the motherboard. Call up the manufacturer again, and see about getting your computer repaired.
Apr 07, 2008 | Acer Aspire E380 ASE380-UD500A PC Desktop
No red color in monitor that is a hp
Power and unplug the monitor and tower. Reseat the monitor plug in to the tower and tighten down.Plug in power cords for both tower and monitor.Reboot computer! If this does not work possible video card failure. ocity10thst@yahoo.com (good question)
Dec 31, 2007 | ViewSonic PS790 19" CRT Monitor
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
