Question about HP Compaq nc6320 Notebook
Same problem in HP dv6040ca
I don't see "Disabling SATA" option in BIOS. There are only two options, Boot sequence and Sound. Is HP dv6040ca upgradeable to XP pro? I've tried removing xp home and reinstalling xp pro from retail CD. As well I tried a latest BIOS and updated AMD driver. Please help me. Seemed HP tech support doesn't know how to do. They keep saying "disable SATA under system configuration in BIOS", but there is no such a thing.
Why disable SATA? SATA native support doesn't allow you to boot from CD.
Posted on Sep 06, 2007
    President:
  • 2,961 Answers
Firstly, the system configuration is normally in management menu or similair on your programmes menu. If not you will find that the bios menu in most laptops are basic and normally the main settings are hidden; you will need to speak to HP Technical for assistance in that. There is no reason to not be able to upgrade to XP Pro; but with an upgrade you would need to keep your original XP Home installation, otherwise you will need to completely install XP Pro firsly using the format option when you insert the Windows disc. As with most laptops all programmes and drivers are usually on a seperate partition on your hardrive, so be aware you are going to lose all this when formatting, so back up all files and settings. You may also have restore discs, if this being the case all programmes and operating system will be on them, so no need to worry about losing anything from your hardrive apart from your documents. Why do you need to dissable SATA?
Posted on Nov 20, 2006
Disable SATA in BIOS, well but there is no option in Bios to disable or enable SATA. Lately HP DV2000 comes with bios without this option (DV2000 - DV2680ee, I lost a lot of money and time with this...
You should not need to disable SATA as it is a way to interface with the hard drive. In the BIOS you can disable a hard drive to boot within the boot options.
May 06, 2011 | Computers & Internet
Picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
Mar 12, 2010 | HP (REFURB) HP DC7100 XPP P4 3.2GHZ 80GB...
I can't use any sata hardwewr on my motherboard
create a sata diskett[floppy] using your motherboard cd and press F6 when booting from xp cd this will install sata raid drivers for your motherboard
Jun 23, 2009 | ASUS P5RD1-VM Motherboard
Pavilion dv7 laptop driver problem BSOD
DV7 is not designed for XP, to get around the issue you may be able to change the BIOS setting for the SATA controller to work in IDE mode(depending on the BIOS) or you can use the XP installer option to install a SATA/RAID driver during the installer boot sequence. To offer you this I will need to know the model # and Serial # on the white sticker on the bottom of your laptop or the make and model of the SATA controller.
Try the Bios option and reply back with the requested info if it's not a viable option and I will see if there is an XP driver available for your controller.
Chris
May 15, 2009 | HP Pavilion dv7z Notebook
Need to get into bios
Dear friend for go BIOS some computers Need to preess DEL, Some Computer need to Press F1, Some Computer need to pree F2. you didnt write about your computer... One solution i have ... Press DELL+F1+F2 At starting your sustem... Here is two option to find out Boot Sequence from BIOS.... some BIOS Have Independent Boot Menu.. IN Boot menu you may see boot sequence... there you have change it. For Other Option You may go the Advanced BIOS Setting Option There you may find First boot device, Second Boot device..... Or Boot sequence.... find out your solution...
For Master And slave..setting in CD/DVD rom ..
set jumper.. near ide or sata cable... for setting as Master...
Set jumper After Master jumper... for setting as slave..
Best Regards.. sumon
Mar 27, 2009 | Computers & Internet
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
HP Cpmpaq Presario V6000
XP wont be able to detect your hdd as you are using a SATA drive. You have two options here
1. Disable SATA function in the bios (easier to do) and use again your XP cd to install the software, it should be able to detect the hdd this time around
2. You have to slip stream the SATA driver to your XP CD and recreate another CD from it. (harder to do). Google "SATA driver slipstream XP" you will be directed to the proper sites
Apr 05, 2008 | HP Compaq Presario V6000T Notebook
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
HP Compaq nc6320 Notebook Logo
99 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
