Question about Nikon D80 Digital Camera with 18-135mm Lens
''HA'' flashing message
Camera won't work until I turn the camera on and off sometimes several times. Lens doesn't seem to make any difference.
  • 90 Answers
PLEASE do the default setup through menu"s
and trying after that
thanks fr trying FIXYA.COM.
Posted on Nov 14, 2008
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Lens stuck out and won't turn on. When I try to turn it on it flashes a red light but it doesn't turn on.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 01, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
I have a fuji A100 10.0 megapixil digital camera. am getting zoom error message and cant get camera to do anything..can you help
Owners manual says "zoom error" indicates a camera malfunction. But, try this, gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur.
Also, sometimes you may have to try several times until you finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Mar 19, 2010 | Fujitsu Cameras
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error "Err05" keeps initiating preventing flash operating
There are two versions of this problem: 1. The flash does not pop-up. 2. The flash does pop-up.
Here’s the fix to the err05 msg when the flash does pop-up. This will work on the XTi and perhaps on similar Canon cameras:
The pop-up flash has two legs. Look at the pivot point of the right leg (”right” when looking into the lens). Just in front of the pivot is a very small spring-load pin on the “roof” of the camera body.
This pin is the sensor that tells the camera the state of the flash. The pin is pushed down when the pop-up flash is closed and is suppose to quickly spring up when the flash is opened. Problem is, the pin sometimes gets dirty and drags. When it is slow to spring up … you get the err05 message.
Fix: Take a small jeweler’s screwdriver and dip the tip in isopropyl alcohol. (Don’t use any other solvent unless it’s designed for cleaning electronic parts!) Then touch the screwdriver tip to the pin. Do this several times until the pin area is nicely wet. Then push the pin up and down until it is able to spring up quickly.
Enjoy.
Jan 20, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Error message on display
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
Oct 16, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Error message
*&%$@#%^&*&^% !!"It's working!!!! Turn your camera on and put it near your ear. Did you hear a softly motorized sound in the lenses area and the green LED is flashing? If you hear this sound do this. Do it under your own responsability. (any way your camera does not work). When you turn on the camera wait until the lenses come out, in that moment grab the lens with your hand and don't let it go back. The camera will turn off but the lens will stay out. With the camera off push in the lens with your hand. Turn on the camera and that's it. I had to do it 2 times, but now my camera it's working again. This system error could be caused because the lens get out of it rail and the camera can not set the focus system.
Oct 18, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
