Question about Evesham Computers & Internet
Machine refuses to power up. Probably needs a new battery.
I have a Quest Roma MS-1209. If I switch it off, remove the battery and wait a couple of days before relacing it, it powers up for a few weeks, then packs up again. I'm scared that one day it won't restart. How do I find a new battery?
Ann
  • Evesham Master
  • 4,806 Answers
Try "DeMontfords" shop on ebay.co.uk, they sell laptop spares, or try a laptop-spares website, can be very expensive though
Posted on Nov 14, 2008
Windows error code 43
known problem, that might be fixed by a cold start. switch off your PC or laptop completely. even pull the power lead from the wall, (in laptop remove power supply and battery once switched off) wait a few minutes and power up and start your machine.
I hope this was helpful
Oct 31, 2013 | Computers & Internet
Advent roma 2001 cmos
If you have dissembled the Laptop and searched the motherboard and not found a CMOS battery, perhaps it uses the laptop battery as a power source? You Laptop is a bit weak on support. Try this forum: http://www.adventsupport.com/viewtopic.php?f=1&t=7380
Jul 03, 2013 | Computers & Internet
Facing automatic switch off problem in nokia 1209
Cell Phone Keeps Shutting Off
Vibrations on dirty battery contacts could be the cause of this problem. Remove the battery and clean the battery contacts with methylated spirits and the battery contacts in the cell phone.
Mar 03, 2013 | Nokia 1209 Cell Phone
I have a HP C6100 All in One error Oxc18a0206 ink failure
Remove all supplies, switch off the machine remove power & usb cable wait couple of minutes.. Power on the machine install the supplies as per appears on screen, check for the error.. For tech guys:
Remove CMOS battery from the formatter, wait for 15 mts, with out battery check for the error. Once error disappears, add CMOS battery...
Jan 04, 2012 | HP PhotoSmart Office Equipment & Supplies
Forgot my security code for nokia 1209, IMEI is 359339/02/806573/7
Hello Mayur,
Switch off the Nokia 1209 Cell Phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia 1209 Cell Phone. Enter the default code 12345 or 00000.Your Nokia 1209 Cell Phone will be unlocked.
Oct 17, 2011 | Nokia 1209 Cell Phone
I was using security code then some one else just enter different code that's all it just went locked
Hello Dani,
Switch off the Nokia 1209 Cell Phone. Remove the battery for 30 minutes.Reinsert the battery and switch on the Nokia 1209 Cell Phone. Enter the default code 12345 or 00000.Your Nokia 1209 Cell Phone will be unlocked.
Sep 06, 2011 | Nokia 1209 Cell Phone
I entered the code 12345 but it is not working wht to do buddies?? reply me urgently
Hello Gajanan,
Switch off the nokia 1209 phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the nokia 1209 phone. Enter the default code 12345 or 00000.Your nokia 1209 phone will be unlocked.
Jul 02, 2011 | Nokia 1209 Cell Phone
How can i change out the ignition switch on 94 nissan quest?
  1. Position the vehicle with the front wheels in a straight ahead position.
  2. Disconnect the negative battery cable.
  3. Disconnect the positive battery cable.
  4. Wait at least ten minutes for the air bag back-up power supply to drain before continuing.
  5. Remove the driver's side lower instrument panel cover. On 1993-94 vehicles, remove the cover screw, then pull out on the cover to release the clips. On 1995 vehicles, remove the five cover screws, then pull out on the cover to release the clips.
  6. Remove the four driver's side lower instrument panel reinforcement bolts and remove the lower reinforcement.
  7. Remove the ignition switch electrical connector bolt and disconnect the connector.
  8. Remove the two ignition switch screws.
  9. Remove the ignition switch from the steering column.
    Removing the driver's side lower instrument panel reinforcement bolts
    Removing the ignition switch electrical connector bolt
    Removing the ignition switch screws
To install:
  1. The installation is the reverse of removal. Tighten the lower instrument panel reinforcement bolts to 29-39 inch lbs. (3.2-4.4 Nm
Jun 13, 2011 | 1994 Nissan Quest
Please I need help. I was using my Hp laptop to play music when it went off and refuse to restart. I removed the battery and re-inserted it again but it still refuse to start then I observed that there was...
Sounds to me like you need a new battery. There are a couple of other things it could be (i.e. the ac power cord) but it is most likely a battery-related issue.
Mar 09, 2009 | HP Compaq nx6110 PC Laptop
Computers & Internet Logo
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
