Question about Singer 5062 Mechanical Sewing Machine
The thread comes out of the needle and the bobbin gathers
When I try to stich, the thread comes out of the needle and the bobbin thread gathers on the underside of the fabric being stiched. This happens repeatedly. The machine worked fine earlier.
  • 2 more comments
  • ksettle Nov 17, 2007
    Have the same probelm
  • Anonymous Apr 28, 2008
    the thread pops out of the needle when I try to sew
  • Anonymous Jun 06, 2008
    thread pops out of needle when i begin to sew
  • ttommargueri Sep 09, 2008
    I have a problem with the bobbin thread. Thread is gathering in big loops on the underside of the material. I used two different colors and discovered the bobbin thread is not even being picked up--it's all spool thread. How can I fix this?
  • 6 Answers
SOURCE: Thread catching and bunching up in bobbin latch while sewing
I had the same problem where the thread was getting all bunched up on the underside. I took everything out and followed the manual concerning threading, then manually moved my right wheel to see if it would get bunched up. It took awhile, but I finally got it sew correctly again. I;m still not sure what was wrong with it. I have a singer 7470.
Posted on Mar 24, 2009
  • 23 Answers
SOURCE: "thread breakage detected"
I had the same problem and one day my 9 year old said Mommy the thread is winding and cathing. I noticed that if the thread is not close to the silver metal arm it coils and makes a knot around the silver feed arm and also sometimes it cathces the little white plastic peace where the silver feed arm is connected to the machine.
Posted on Apr 01, 2009
  • 4088 Answers
SOURCE: needle thread is missing the bobbin catcher
Suspect the lower drive mechanism is out of time with the upper drive. See your local service agency for repair.
Posted on Nov 25, 2009
Testimonial: "this gave me the exact info that I need to fix the problem thank you drallim. now I can just look at the machine diagram and make it happen. thank u"
RickE1
  • 202 Answers
SOURCE: thread mess at the underside of the fabric
Hi, maybe your bobbin is turning the wrong way and you need to flip it over. Or you don't have any top tension. Be sure the thread is in between the tension disks with the foot up. Its also possible that there is a burr on the hook part that goes around and grabs the top thread. The thread will catch on the burr and cause this issue. Usually after breaking a needle. Then the burr would need to be polished off.
Posted on Mar 18, 2010
wcbotha
  • 92 Answers
On the bobbin holder there is a smaal screw, thghten the screw to set tention on the bobbin thred. The thred you use on top and in the bobbin can be the problem as well E-Mail me wcbotha@yahoo.com
Posted on May 12, 2010
Help! I'm having problems with my Necchi Lydia 3. Firstly when threading up, the threaded needle refuses to draw up the bobbin thread. I've followed the instructions and the needle comes in and out but...
try a different bobbin
make sure the bobbin in turned the right way in the bobbin case
also the machine may have a timing problem, and having it checked to would be a good idea.
Sep 07, 2013 | Necchi 4575 Mechanical Sewing Machine
Nv500 brother machine maked a grinding sound and wont stitch it just gathers and knots can you sugest what it might be?
Something is bound up. Stop trying to sew. Turn off the machine.
Take off the foot, take out the needle, take off the bobbin cover, take of the needle/throat plate and check for the reason for your problem. Look for lint, threads caught up underneath and in between the parts.
Clear all that out and put it back together and attempt test seam.
Nov 19, 2012 | Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
When i try to sew after i have pulled the bobbin thread through no stiches are formed both threads are on top but no stiches are formed
Be sure your bobbin is inserted correctly. This is usually the main cause for the stitch not being made. If that's not the answer, be sure the upper threading is correct. If a thread guide is not threaded or if the thread does not go between the tension plates, this might cause your problem.And of course, make sure the needle is inserted with the groove toward you and that it is inserted completely in the needle channel. If none of these are the problem, the bobbin case may need to be adjusted or checked for burrs. I really hope this helps you. If it does, please come back to Fixya and rate my advice.
Aug 01, 2011 | Singer Sewing Machines
The thread comes out of the needle and does not make stiches. I have rethreaded it back several times and it does not make a stich.
The needle may not be set ( pushed in all the way)? You may have the tension too tight and the thread may be breaking? Your hook in the shuttle may be bent ( the reason for the needle not taking up the thread from the bobbin? Needle may be bent? Try a different needle and make sure that it is in the right orientation.
Feb 20, 2011 | Consew 206RB
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
My machine gathers thread in the bobbin and then the thread breaks off.
check the needle to see if it's damaged
some sewing machines gather thread in the bobbin area when the thread come off the thread take up lever
check the bobbin & bobbin area for burrs
Sep 23, 2010 | Singer Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
JONES SEWING MACHINE PROBLEMS
We have a very old Jones Sewing Machine (1960's) we are having trouble with the thread at the moment. When we sew the thread gathers up underneath the material that we are trying to sew. Any suggestions to overcome this problem?
Feb 21, 2009 | Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Singer 5062 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
