Question about E-Machines eMachines Desktop PC
Computer's screen resolution not matching monitor's optimum
(1440X900) setting. How do I adjust screen resolution?
  • JDTec
    JDTec May 11, 2010
    Unless you have a hi-end monitor, the 1440x900 resolution will not work on most monitors.
    Do you have Vista or XP?
    Problem Solver:
  • 8 Answers
If you are using Windows XP, you can right click on your desktop wallpaper and select the "Display" text, this will bring you to a properties window. Once that comes up, there should be tabs listed near the top of the window, click the LAST tab. On the left of this window now should be a slider with numbers at either end. It is best to try out each setting one by one, simply by adjusting the slider one "notch" to the right each time, and pressing Apply.
If your monitor blanks out for more than 5 seconds, press ESC to go back to your previous setting, which will be your maximum supported resolution.
If you are on Vista, you can do the same thing, but instead of going to "Display", you have to go to "Personalization" on the right click menu, the select "Display Settings" in the window that comes up.
Posted on Nov 14, 2008
I have asus vw192t 19"
Resolution capabilities are a complicated blend of the abilities of your graphics card and the abilities of your screen. You will not always get a 1:1 match. You can improve your chances by installing the "monitor information" file that is usually supplied on a CD that comes with the monitor. Also, updating the drivers for your graphics card (see the manufacturer's web site) might help.
Mar 23, 2011 | ASUS VW192T Monitor
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
I have a resolution problem which happens each time i try to play one game. my monitor is SyncMaster 932MW and when i start this game the screen goes blank and i get the msg: not optimum mode, recommended...
mozzarellait
It sounds like you have a driver problem. I would recommend that you reinstall the drivers for your video card. After that I would make sure that you install the drivers for your monitor. 1440x900 is not a standard resolution so the Windows default monitor driver may not have the proper refresh rate for your monitor. If you monitor drivers do not have a installer the link below will help you install them.
How to install your monitor drivers in Windows 7
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Oct 01, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
How do i set my x193w lcd monitor to hd?
install the CD that came with the monitor else right click on monitor screen in windows and adjust on properties menu
Nov 22, 2009 | Acer X193W LCD Monitor
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
Screen resolution reminder.
go to the control panel double click DISPLAY then select setting then select 1440x900
Jan 09, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
