Question about Dual XINBP212 Car Subwoofer
Speakers keep cutting out and the box starts smoking...
Ok so i just got some new wires and the wieres and the hookup is fine but im pretty sure there is some wires touching in the back part of the sub and are making it smoke...but i dont know gow to get to the back part of the sub box...or how to fix it?
Most likly if its smoking, and you replased your wires then your speeker coweols may have moved together from overdriving the subs and are slighly tuching. Wich would mean you need to just get new ones. Im looking to buy some of theas and that is something severol people have been having problems with from over driving the subs. ps. sry bout the spelling, lol
Posted on Jan 27, 2007
Go through the front end and remove speakers
Posted on Nov 04, 2007
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Jl 12w3v3 started smoking after hookup
Dang man you roasted it, take it in and get it replaced.Check the gain on the amp try it at 1/3 to 1/2 gain and dont crank up the bass boost all the way try it at like 2/3 that should clean up your sound and cut down distortion-distortion kills subs by heat.
Jan 31, 2010 | Jl Audio 12W3v3-4 Car Subwoofer
Im trying to hook up some roof marker lamps so they come on when i turn my running lights on
just run it threw the fuse box with the running lights and be sure to ground it.
Jan 25, 2010 | 1999 Chevrolet S-10 Pickup
97 Jeep Wrangler Dash Gauges Arent Operating..everything else ok!
check fuse #17 in fuse box under hood. It's a 10 red fuse. that's how i fixed my problem.
Dec 20, 2008 | 1997 Jeep Wrangler
Radion will not turn on, batteries OK and in correctly
the wieres might have accidentalt ben pulled from the battery hookup or the screen or speaker has blown out
Dec 11, 2008 | Cherokee FR-460 (14 Channels) 2-Way Radio
ZX700.5 cutting out at 60% volume
I figured out the problem, the front right tweeter wire was pinched behind the mounting bracket. everything is now working perfectly.
Sep 22, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Need To Install pioneer ts-g950m speaker in my car
i did this with mine, hook more wire to the wire that holds the clamp , then solder it or wrap it around the terminals on the speakers
Jun 06, 2008 | Pioneer TS-G950M Coaxial Car Speaker
Amp on but no bass
1st make sure the speakers are not bad, check th eimpedance with a multimeter, the voice ciols should read 3.9 to 4.3 ohm's. if any of your subs are below this most likly the subs are bad. if they are ok make sure the ground for the amp is good. now the last thing is the amp. try another pair of speakers, even if it's smaller ones, just make sure they are 4 ohm speakers, keep the vol. very low during your test. if the other speakers do not work then have your amp serviced or replaced. good luck
Dec 19, 2006 | Kenwood KAC-8101D Car Audio Amplifier
Yamaha htr-5830
The amplifier protection circuit is kicking in. There are a number of possible reasons. One is that you have a problem with your speakers or speaker wiring. Carefully inspect your speakers for any changes, and examine the wires looking for shorts or opens. If it isn't a speaker problem, then something in the amp is triggering the protection event. It could be thermal (something getting too hot). That could be due to bad air circulation, dust, or an electronic component failure. A second event would be DC voltage on the speaker outputs. This could be due to a bad capacitor, leaky semiconductor, or the bias adjustment (if it has one) that needs to be reset. A third event would be high current draw. That most likely would be due to a semiconductor that is about to blow. You should have this checked out. If you keep doing your override, you may blow out something that wouldn't otherwise fail. Or you can wait for something to blow, and then it would be much easier to find the root cause (just look for the smoke).
Dec 13, 2005 | Yamaha HTR-5830 Receiver
Dual XINBP212 Car Subwoofer Logo
116 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
