Question about Hitachi 50VS69 50" Projection HDTV
Bluish hazy texture on my screen
About 2 months ago I noticed a dark spot on my screen when there was a white background. Over time this has changed to a bluish hazy texture all around the outer edges of the screen all the time. Also I have noticed about 10 small tiny blue dots spread out in the upper right hand corner of the screen. It kind of resemble the milky way galaxy with tiny stars shining through.
It sound like the light engine is going out or already out. I would take it to a certified Hitachi dealer have them check it out then I would call Hitachi to have them fix it for free.
Posted on Dec 28, 2008
My LG tv model 50LB6300 ( 50 inch ) had 3 months ago 1 bright spot on the screen. After 1 month there came 2 more. And today it is 5. These white spots become very bright at a white background.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 03, 2017 | LG Televison & Video
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
White smoke coming out of tail pipe.
WHITE smoke? Or BLUE smoke? White smoke is usually caused by burning antifreeze (possible blown head gasket). Engine oil burning causes a bluish colored smoke.
Changing the oil two months ago means absolutely nothing to me. I have customers that travel 6000 miles or more in a month. Oil consumption is measured in volume over miles, not volume over months. It is normal for most 4 cylinder engines to use a little less than 1/2 quart in 1000 miles (even more than that for 6 cylinder and 8 cylinder engines).
Apr 12, 2012 | Cars & Trucks
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
Red spot on LCD
1) That red spot means that a pixel is stuck, actually it's very common on LCDs.
2 and 3) It usually occurs for a manufacturing issue.
4) The most of the time it doesn't mean that the whole screen is going to fail, but in my case I would take advantage of the warranty if the laptop is brand new and the warranty is still there.
Good Luck!!!
Feb 24, 2009 | Computers & Internet
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
211 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
