SOURCE: DIsable touch pad on Inspiron 1501 laptop with XP
In your system you should be using synaptics touchpad driver. First of all look for it under mouse properties in control panel. If its not there then install in from support.dell.com. Under this application you would be having option to disable touchpad when external mouse connected. Try this.
Please rate the comment
SOURCE: dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
SOURCE: HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
SOURCE: dell latitude d600...i want to disable my
Hi MKW,
I know the feeling. Here we go,
That ought to do it. Hope you found this to be very helpful.
Mike
