Question about Panasonic NN-S254BF Microwave Oven
No power to Panasonic NN-S252 microwave oven
Unit was working ok one minute, then when I tried to use it again a few minutes later the display was blank and nothing worked, like it had lost power.
Main circuit breaker checked and power to outlet is ok.
Does it have a "built-in" fuse, breaker or reset? If so where is it located?
Any and all suggestions greatly appreciated!!
  • 1 more comment
  • fwalker202 Nov 16, 2008
    Decided to just go ahead and open the darn thing up.
    Very easy, just pull off the grill across the top, remove 2 screws at the top of the control panel, and lift the control panel up and out. The fuse can then be seen, removed and replaced. After removing the fuse and checking with Volt-Ohm-Meter, found it open. Now all I need to do is find a replacement and hope that it doesn't blow again.
    Radio Shack sells a box of four 20A fuses for microwave ovens for $3, Great!!
  • fwalker202 Nov 18, 2008
    Replaced the fuse (20A from Radio Shack) and its working again!!
    Clock and all controls check out and working like before.
    Used it several times now with no problems.
  • claudeoram Feb 26, 2009
    Don't want to force the grill across the top. Right side is loose but left
    is very tight, I assume clips as I can not see any screws holding the
    grill. Should I just force the left side a little harder. I can see the two
    screws holding the control panel that I would like to remove to get at the
    fuse.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
Follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Posted on Feb 20, 2010
Where is the fuse on Panasonic NN-S252
You may have to remove the cover on the microwave to find a fuse. It may not be either in a fuse holder or soldered into a the circuit board. be sure it is not plug up when you check.
if you find it be sure and replace with the fuse with same current rating.
Aug 01, 2014 | Panasonic NN-S252WF Microwave Oven
Panasonic NN-T993SF microwave oven LCD display is out. The keypad is working fine and also the unit is working fine except the LCD display.
The display is part number AEDDHJ5W00AP.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 08, 2011 | Panasonic NN-T993SF Microwave Oven
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Model NN 9804 U microwave in Demo Mode
No owner's manual?
If you're in the US, find it here.
If you're not in the US, see Panasonic.net and look for support / download links.
Otherwise, I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 14, 2010 | Panasonic NN-T888S Convection/Microwave...
Will not turn on, clock & light do not work, breaker on
try unpluggin it for a few minutes then pluggin it back in, but it sounds like it has been hit by a power surge.
Dec 30, 2008 | Panasonic NN-T793SF Microwave Oven
New Microwave not working
If it's still not working, you'll need to contact your nearest Panasonic-authorized servicer.
Aug 24, 2008 | Panasonic NN-P295SF Microwave Oven
The microwave does not work.
Let us know if the hard reset does not fix it.
You may have a failed keypad or control board.
We repair these for customers nationwide with our guaranteed $39.95 service.
Aug 07, 2008 | Whirlpool GH7155XHS Microwave Oven
Turning off before finishing time time cycle
I have just had this problem where the oven will only run for 5 seconds and then turns off model #NNS561. Cant find any solution.
Jan 19, 2008 | Panasonic NN-S950BA Microwave Oven
check control circuit and related control panel circuit
Jul 28, 2007 | Panasonic NN-T993SF Microwave Oven
Panasonic NN-S254BF Microwave Oven Logo
565 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
