Dsl sync my modem will not sync up with my dsl signal. im getting a signal btu im not recieving a signal, why?
  • 21 Answers
The question I have is,
1. Did you have sync previously and it has suddenly stopped working?
2. Is this new a new DSL activation of service to your address and has not achieved sync yet?
for 1.
The most common issue is usually a recent change within the telephone environment or equipment at your address, does any of the following fit your scenario: You recently moved your DSL equipment to another room, you have bought a new phone, answer machine, Fax machine, Sky television subscription, a monitored security alarm service has been installed at your address or health monitoring equipment has been installed or an unlikely, lightening strike or power outage has occurred around the same time as sync was lost.
Any of the previous changes may have altered the way DSL signal is being filtered or split from your standard home phone signal, all telephone line using devices except for the modem/router will need to have its own DSL filter, if security or health monitoring was installed you will need to contact your internet provider and request a line splitter installation (this can be at some cost to the user, so don't forget to check what a local electrician can do this same job for)
DSL Filters can also be very susceptible to problems after power surge/failure or lightening strike at your address. Or if you have recently moved your DSL equipment, please double check the way you have setup the filter and cables at its new location.
The only test required to verify the issue is not at your address is known as an ISOLATION TEST. The router must be checked in a Phone signal free environment, please remove all phone cables from all jack-points within your premis and plug in only your router, without a filter, you should also test your router across all the jackpoints at your address if the first phone-jack you try fails) If we got lucky, you now have sync and the problem lies with one of your phone line using devices or the filter that it is using, start plugging each device back into the phone circuit one device at a time, with a filter and check to see if the router has lost sync after each device is plugged back in until you are able to identify the problem device, filter or jack-point.
for 2.
Follow the directions exactly as above and if no problem devices, filters or jack-points are found, then ISOLATE your router again and call your ISP provider and request firstly a "port reset" for your DSL port, this should be achieved within a 24Hr period, some are able to do this within 20min of your call, if sync will still not come up it is time for the ISP or service provider to send out a technician to verify the issue is not at the port, cabinet or exchange, this may take some providers up to 5 days to achieve.
Some last thoughts,
Dont rule out the possibilty of the Phone cable used for the router has failed (test the cable on a working home phone to verify it is still working)
or you may have bought an extension cable for your router, the length of Ph cable between your router and the jack-point can be no longer than 5meters before DSL signal fade can start to occur, the router will work at its best with a 15cm-30cm Phone cable, the 1meter cable usually supplied is fine.
Also, do check the jackpoints that you are NOT using at this premis (rare occasions have found me resolving sync issues because the vaccum cleaner has taken out one of your unused jack-points under the bed, in the spare room or the neighbours visiting toddler has tried to plug in a jam sandwhich or even a small plastic toy of some sort into an unused jackpoint)
If you are able, do check that your router can get sync and connect Ok at an address where DSL signal and Sync is currently known to be working.
If you have just moved to this address and your property is over 40-50Yrs old, you may want to check with the phone line provider to see if "line insulators" have ever been installed previously to resolve line noise issues, ageing line insulators will corrupt your DSL signal especially on the high humidity days.
I realise this must seem quite broad and intensive, this testing is intended to rule out any possibility of the issue being internal to your address (as we all know TELCO technicians are all too eager to hit you with unexpected maintenance charges if the issue is found to be internal to your property, as opposed to external)
Hope this gets you closer to identifying the source of your DSL sync issues, if you are like the many DSL subscribers out there, you cant stand to be without your high speed internet for more than two minutes either.
Happy hunting.
Posted on Nov 14, 2008
Sync wrt54g2v1 router to modem?
Turn off the modem (i am assuming you are using a cable modem. if it is a DSL modem, this will not work) and the router. Turn the modem back on and wait until all the LED's on the front of the modem come on and blink or stay solid, then turn the router on. If it is DSL, you will have to refer to this page:
Jan 19, 2013 | Linksys WRT160N Wireless Router
I have a motorola high speed dsl modem (MSTATEA) and a netgear router(Wnr2000v2) and it lets me on my computer but everytime i try to play xbox live it lets me play for a little then it randomly resets,...
Contact your ISP- the issue is not likely the modem in this case. I suspect you may have an intermittent signal (sync) issue- you're losing signal, so a connection that is *very* state oriented *cough*Halo*cough* would cause you to see the issue a little more clearer than a connection that is a little more passive- for instance surfing on the web.
Dec 07, 2010 | Arris High Speed DSL Modem
My linksys WRT150N router won't recieve internet signal from my dsl modem. The router sends out a signal to my lap top, but no internet connection can be made.
Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
If the dsl modem is working correctly then:
1. Turn off the power on the router and dsl modem.
2. After about 2 minutes, turn on the dsl modem.
3. Wait another 2 minutes, then turn on the router.
Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
Dec 27, 2009 | Linksys Wireless-N WRT150N Router
Assistance with blinking light on my DSL modem
First thing to do is unplug your DSL modem and leave it unplugged for about a minute then plug it back in and see if problem is corrected. If not you should contact your ISP tech support. You could have a bad line from the phone company or bad connection in your house. Also if you have filters installed on your other phones you can have a bad filter that is causing interference and keeping yoiur DSL from working properly. You should go to "Start" > "Run" and type cmd and hit "Enter"
In the command window type ping -t (Enter) This will start a continual ping. If you are getting ping times exceeding 70 - 120 ms that could be a sign your DSL is not functioning properly or if you get packet loss. That is when the ping time doesn't return a time periodically.
Sep 23, 2009 | Westell Wirespeed LiteLine 6100...
I dont know what the telephone light means
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 14, 2009 | Belkin (F5D5231-4) Router
2700HG Can't Sync to DSL Signal
The gateway is made by 2Wire contact them for repair.
Sep 12, 2008 | 2wire 2700HG-B Router (2700HGB)
I can't get on line
A blinking DSL light means that you have no DSL sync -- you are not receiving a digital signal. You will need to contact your ISP to have them repair your service.
Steps to do first:
1. Powercycle the modem -- unplug the power from the back for 15 secs, plug it back up.
2. Ensure that all phones that share a line with the DSL have filters attached.
Jan 28, 2008 | Westell Wirespeed LiteLine 6100...
DSL light flashing
Not-sync'd = No dsl signal.
First thing first- Unplug your modem for 10 seconds or so. Then see if your lights all come back on.
If you have phone service with your dsl, make sure you have dial tone in the phone jack you're trying to use. If not, then try a different phone jack. If you still can't get your dsl to work, then call the phone company and have them come out and fix your dsl.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
1,353 people viewed this question
David Payne
David Payne
