Question about Canon PIXMA MP150 All-In-One InkJet Printer
The ink cartridges
I have tried to install the ink cartridges, and still the copier does not work. I want to know if I am installing them properly.
I attempted to replace both cartridges in my printer. I can't get them to lock in place. How is this properly accomplished?
Posted on Nov 14, 2008
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Printer dosen't work
The ink cartridges are
not installed[1401],
or a non-supported ink
cartridge is
installed[1485],
or the ink cartridges are
not installed
properly[1687].
Check if supported ink
tank(s) is installed, and
re-install them properly,
and then close the
scanning unit.
Jul 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Installing ink cartridges
don't know how to install ink in my f4180 printer. Have new cartridges 21 and 22
May 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
E5 problem
E5, says the ink cartridges are the wrong type, not properly installed, or not installed at all. You can't refill those without replacing the chip or resetting the chip. Many refilled cartridges just don't work...
Aug 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Installation of the cartridge for Canon Pixma iP1600 printer
To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
cartthingsnottotouch.jpg3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
ip1600puttinginink.gif4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Jan 06, 2009 | Canon PIXMA iP1600 Printer
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
E5 error when turning on printer
E5 means The ink cartridges are not installed or a non-supported ink cartridge is installed ,or the ink cartridges are not installed properly. Try to remove the cartridge and re-install it and make sure it is seated properly. If this doesn't work then let me know and i will get you the reset procedure..
Jul 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Inkjet cartridges
Hello hotstikss
The following are some error messages, if you are getting any of these, then you will have to investigate by reinstalling the cartridge or installing a new one.
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
If this does not sove the problem please let me know.
Thanks
Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
