Where is the CMOS battery located?
On most desktops, it will be located on the motherboard, sitting in a slot socket. These batteries look like nickels and sit in the socket with their positive side up. They are usually held in place by a tension spring.
If you have a laptop, then the battery maybe accessible through an access door on the bottom of the case. These batteries can also be a disc type battery sitting in a slot or it can have a special covering with a small cable attached to it, this small plug attaches into a socket. In some cases, the laptop has to be disassembled in order to remove or observe the battery.
WHERE IS THE CMOS CONNECTOR LOCATED ON THE SYSTEMAX 2004 MODEL? WHAT DOES IT LOOK LIKE/WIRING HARNESS? DIAGRAM? DO I LEAVE IT UNPLUGGED'OR REATTACH?
